What is this?
Topic author - Posts: 5540
- Last Name: Hatch
What is this?
Is this a Fun Projects mag battery charger? Any one have hook up diagram? Does it have one lead hooks to mag?
Email me at address in pictures if you want to. Thanks Day
- Last Name: Hatch
Re: What is this?
Is this bitter engineering battery charger?
Re: What is this?
Looks like old Radio Shack parts. Would help to see lettering on components, Also what is the brown tube connected to. --
Fun Projects Mag Charger (just a diode & bulb)
- Last Name: Hatch
Re: What is this?
That is a fuse holder that is part of the turn signals.
I wonder if that circuit board is this?
https://www.snydersantiqueauto.com/cont ... 5165-6.pdf
Arbs
- Last Name: A
- Board Member Since: 2022
Re: What is this?
Dan,
Can you get a close up with more detail?
Re: What is this?
Not a Bitner set-up.
- Last Name: Hatch
Re: What is this?
Try this .Has to be a mag battery charger.
Yellow wire is 12v in
Green is 12v out
Red has no voltage. Must hook to mag.
It is like the Bitter.
Green is 12v out
- Last Name: Tannehill
- Board Member Since: 2002
Re: What is this?
Dan I believe that’s a Seth Harbuck mag charger. Seth made one very similar to the one pictured. You may recall he was an early proponent (2005) of the ability for the mag to charge the battery. He sent out several to friends including me for a 1915 roadster.
Best John
Best John
- Last Name: Hatch
Re: What is this?
John by chance do you have the instructions for it still? Thanks for the help. Dan
Arbs
- Last Name: A
Re: What is this?
The part with the heat sink looks like a voltage regulator. Everything else looks like resistors and one transistor. You may be right, could be a homemade mag charger. These components would be all you would need.
Re: What is this?
If the Heat Sink part # is S4008FS21 see https://datasheetz.com/data/Discrete%20 ... heetz.html
varmint
- First Name: Vernon
- Last Name: Worley
Re: What is this?
Not and electronics engineer but used to play with this stuff 50 years ago.
This is my guess:
This is my guess:
Vern (Vieux Carre)
- Last Name: Hatch
Re: What is this?
I know what the parts are. I want to know if it is battery charger, which I know it is. And who made it , how it hooks up.
I pulled a big screw up and unhooked it pulling the engine to fix cracked drums. Oh I will remember how that goes, yeah right.
Well with all else going on guess what? I think I have got it right so we shall see.
