Needle point, fuel-air ratio
jaybee47
Topic author - Posts: 357
- First Name: jay
- Last Name: bolante
- * REQUIRED* Type and Year of Model Ts owned: 1922 Runabout
Which figure would provide a finer adjustment for the fuel-air ratio?
Daisy Mae
- First Name: Kurt
- Last Name: Andersson
- Board Member Since: 2024
Re: Needle point, fuel-air ratio
Finer/longer the taper the slower the change per twist...
Shorter the taper doesn't take much to twist full open...
Figure B = finer degree of adjustment, presuming threads being equal.
