Wheel bolts, nuts and loose lugs
Post by Allan » Sun Sep 01, 2024 3:48 am
I learned something today. Among the assorted wheel bolts and loose lugs I have accumulated over the years, there have been a few longer bolts and a few U shaped loose lugs which were wider than the usual ones on our Canadian sourced Kelsey loose lug wheels. Parked next to me today at an old car event was a Dodge with 21" split rim wheels with the two holes either side of the split just like Canadian 26-7 T rims, but without the fixed lugs. The felloes on the wheels were deeper than our T wheels, so the U shaped loose lugs had a wider spread on the feet of the lugs. The bolts were longer too, but they used the same nuts as the T ones with the squared off flange simulating a washer, just like our T nuts.
m_p_dean@yahoo.com
First Name: Maurice
Last Name: Dean
* REQUIRED* Type and Year of Model Ts owned: 1917 Touring Car
Re: Wheel bolts, nuts and loose lugs
Post by m_p_dean@yahoo.com » Sun Sep 01, 2024 9:52 am
You parked next to a DODGE?!?
Post by Allan » Sun Sep 01, 2024 7:28 pm
It was right next to the loo Maurice.
