Muncie transmission mount
Reno Speedster
First Name: Morgan
Last Name: Blanchard
* REQUIRED* Type and Year of Model Ts owned: 1926 Model T Speedster Project, 1922 Runabout Pickup
Post by Reno Speedster » Tue Sep 10, 2024 12:51 am
I am getting close to the point where the rear axle is ready to go in so I am looking at other parts that need to be in place. I have a nice Muncie that I am using in this car. I have the proper connectors and the support, but I don’t have the hardware for mounting the support. The manual shows a couple of “U” bolts that go over the top of the frame then pass through the mount to hold it on. The manual shows two springs below the mount held on with nuts. I am not sure how stiff these springs need to be and how tightly things need to be tightened down. Can someone who has an original Muncie mount give me a hint on the proper setup and springs to use?
AEyssen
First Name: Alex
Last Name: Eyssen
Re: Muncie transmission mount
Post by AEyssen » Tue Sep 17, 2024 10:31 pm
Not sure it’s best, but we made a simple angle iron bracket with welded tabs to bolt onto the Muncie. It won’t flex. We might need some springs on the frame mount based upon your image. Thanks for posting.
1915 Model T Touring
Post by TRDxB2 » Wed Sep 18, 2024 10:50 am
Just thinking that these should work (if ID matches) since they're used for wishbone
For a previous discussion (maybe new owner can help) https://mtfca.com/phpBB3/viewtopic.php?t=31335
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Thu Sep 19, 2024 10:35 pm
Thanks for the tips.
