Today I made a stand.
Topic author - Posts: 7083
I have orders from my better half for a particular project. It needs a head high stand, so down to the T scap pile I went.
Just two components and I was done. That's a non starter flywheel for the base and a late driveshaft housing for the column. Two magnet retaining bolts were used to bolt the two pieces together. The flange is a perfect fit in the flywheel recess and the two bolts simply go through the dowel pin holes. Allan from down under.
Re: Today I made a stand.
Made for each other!
Bryant
- First Name: Bryant
- Last Name: Shafer
Add a light switch assembly and bulb. Throw a lamp shade on it and put it in your living room!
Bryant
Bryant
- Last Name: House
And your wife Allan…. did she ‘Take a Stand’ ?
George, it was her request. When I get the top part mounted all will be explained.
- Last Name: Patrick
No matter how proud of it I might be, my wife wouldn’t allow “that Rusty thing” in the house.
I'd make a hat rack out of that! Put 4 claw feet on it and add some antlers at the top to hang hats or coats on, and put an LED light in the u-joint bell... or maybe a small garden gnome(?)
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Your approach is all wrong- that's not rust, its "patina"!!
