I am trying to source a Magneto Coupler (-similar to a Lovejoy Coupler)
Topic author - Posts: 446
- First Name: Brent
- Last Name: Terry
- * REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1915 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
I am trying to source a vintage looking Magneto-type Coupler that has a 0.750" diameter, keyed-shaft bore on one end, -and a 0.500" keyed-shaft bore opening on the opposite side. At last resort I'll consider using a modern coupler, but if someone knows of a source to purchase one, I would appreciate it.
Thanks.
Thanks.
- Last Name: Hatch
Re: I am trying to source a Magneto Coupler (-similar to a Lovejoy Coupler)
Brent look at a TB Woods Sure Flex Plus couplings. Also used by Bell&Gossett pumps. Maybe what you are looking for. Dan
- First Name: Kevin
- Last Name: Pharis
The MATCO side drive magneto front plate used 1” diameter hubs with a short section of fabric reinforced rubber tubing clamped on. Infinitely adjustable, self aligning, authentic, and reliable. Don’t seem to have any pics on my phone but will try to find later…
Restoration Hardware has a brass adjustable coupling that is infinitely adjustable and nicely made. I believe it only has pilot bores in each end, you machine to fit
- First Name: Erik
- Last Name: Johnson
My father has these available.
He purchased them from Fenstermacher Automobile Supply here in Minneapolis about 70 years ago. Also shown is a clipping from the Fenstermacher catalog.
I believe you can take the six pieces shown and group them in various combinations.
If you are interested, I'll take measurements and ask how much he wants for them.
Do a search for Oldham Couplings.
- First Name: Brent
- Last Name: Terry
Erik, that would be great. Feel free to PM me when you have the particulars.Erik Johnson wrote: ↑Thu Sep 12, 2024 10:57 amMy father has these available. He purchased them from Fenstermacher Automobile Supply here in Minneapolis about 70 years ago. Also shown is a clipping from the Fenstermacher catalog. I believe you can take the six pieces shown and group them in various combinations.
Thank you Jerry, that is another name for those that I was unfamiliar with. I will see what they have.
- First Name: Erik
Brent:
I sent you a private message.
Erik
Erik
- First Name: Kevin
- Last Name: Fielding
Brent,
Restoration Supply out in Escondido California, had some made up that were able to be adjusted for timing.
I remember they weren't cheap but may be a solution for your problem,
Hope it helps,
Kevin
Hope it helps,
Kevin
