I am trying to source a Magneto Coupler (-similar to a Lovejoy Coupler)
BRENT in 10-uh-C
First Name: Brent
Last Name: Terry
* REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1915 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
Post by BRENT in 10-uh-C » Thu Sep 12, 2024 7:58 am
I am trying to source a vintage looking Magneto-type Coupler that has a 0.750" diameter, keyed-shaft bore on one end, -and a 0.500" keyed-shaft bore opening on the opposite side. At last resort I'll consider using a modern coupler, but if someone knows of a source to purchase one, I would appreciate it.
Thanks.
Last Name: Hatch
Re: I am trying to source a Magneto Coupler (-similar to a Lovejoy Coupler)
Post by Dan Hatch » Thu Sep 12, 2024 9:50 am
Brent look at a TB Woods Sure Flex Plus couplings. Also used by Bell&Gossett pumps. Maybe what you are looking for. Dan
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Thu Sep 12, 2024 10:22 am
The MATCO side drive magneto front plate used 1” diameter hubs with a short section of fabric reinforced rubber tubing clamped on. Infinitely adjustable, self aligning, authentic, and reliable. Don’t seem to have any pics on my phone but will try to find later…
Restoration Hardware has a brass adjustable coupling that is infinitely adjustable and nicely made. I believe it only has pilot bores in each end, you machine to fit
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Thu Sep 12, 2024 10:57 am
My father has these available.
He purchased them from Fenstermacher Automobile Supply here in Minneapolis about 70 years ago. Also shown is a clipping from the Fenstermacher catalog.
I believe you can take the six pieces shown and group them in various combinations.
If you are interested, I'll take measurements and ask how much he wants for them.
Post by Jerry VanOoteghem » Thu Sep 12, 2024 11:18 am
Do a search for Oldham Couplings.
BRENT in 10-uh-C
First Name: Brent
Last Name: Terry
Post by BRENT in 10-uh-C » Thu Sep 12, 2024 11:40 am
My father has these available. He purchased them from Fenstermacher Automobile Supply here in Minneapolis about 70 years ago. Also shown is a clipping from the Fenstermacher catalog. I believe you can take the six pieces shown and group them in various combinations.
Erik, that would be great. Feel free to PM me when you have the particulars.
Thank you Jerry, that is another name for those that I was unfamiliar with. I will see what they have.
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Tue Sep 24, 2024 11:36 am
Brent:
I sent you a private message.
Erik
kevinf
First Name: Kevin
Last Name: Fielding
Post by kevinf » Wed Sep 25, 2024 10:08 am
Brent,
Restoration Supply out in Escondido California, had some made up that were able to be adjusted for timing.
I remember they weren't cheap but may be a solution for your problem,
Hope it helps,
Kevin
