NOS Valve Spring Seat source?
				cwlittle
- First Name: Charles
- Last Name: Little
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1924 Del. Truck, 1924 Touring
On researching valve spring seats on the forum I note that there are several doscussions relating to the poor quality of the repro valve spring seats and the comment: "only use NOS"! Okay, where do I get the NOS ones?
									Charlie Little, South Paris, Maine
				cwlittle
- Last Name: Little
Re: NOS Valve Spring Seat source?
BTT,
Anyone know where I can get the old, NOS, thicker, valve spring seats???????
Try first by making a  call to the vendors that have lots of used or original parts, Bob's Antique Auto, or Lang's Antique Auto Parts.
Next place an classified free adv. for a set, you might get them that way. Lots of good used ones are out there too, ask for a pile of good used and sort, most have very little wear, some might have cross pin grooves, but cull those away.
The best way is always the simplest. The attics of the world are cluttered up with complicated failures.     Henry Ford
				Kerry
- Last Name: van Ekeren
Haven't found the replacement new ones to be of a poorer quality for several years.
				Adam
- First Name: Adam
- Last Name: Doleshal
The major problem inside the last 15 years was the pins more than anything.
Of course, many hobbyists and some engine builders don’t know to turn the spring in the block until the keeper rests level... Failure to do this might result in some odd wear and other “unusual” issues.
				Greg Griffin
- First Name: Greg
- Last Name: Griffin
- * REQUIRED* Type and Year of Model Ts owned: '14 torpedo, '25ish pickup
Hmmm...  I didn't know that either.  Thanks.
Use to find them at swap meets when folks would have cans of T parts to sell. Pretty common to usually find good ones.
What is wrong with used ones? I've never seen a worn out one yet!
JP_noonan
- Last Name: Noonan
- * REQUIRED* Type and Year of Model Ts owned: 1925 Runabout
A few years back i decided to do a complete valve job including new valves, springs, caps and pins. Shortly after, i read here about the questionable spring caps that were causing problems and was worried about it myself. Not sure how long the bad batch was in effect, but i have checked mine on occasion, and it all seems fine so far. Here's an older thread that discusses this problem. Hopefully it has been addressed and all is well.
http://www.mtfca.com/discus/messages/50 ... 1450555390
Experience is a wonderful thing. It enables you to recognize a mistake when you make it again.
