NOS Valve Spring Seat source?
cwlittle
First Name: Charles
Last Name: Little
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1924 Del. Truck, 1924 Touring
Post by cwlittle » Thu Jun 13, 2019 5:51 pm
On researching valve spring seats on the forum I note that there are several doscussions relating to the poor quality of the repro valve spring seats and the comment: "only use NOS"! Okay, where do I get the NOS ones?
Charlie Little, South Paris, Maine
cwlittle
First Name: Charles
Last Name: Little
Re: NOS Valve Spring Seat source?
Post by cwlittle » Fri Jun 14, 2019 5:13 pm
BTT,
Anyone know where I can get the old, NOS, thicker, valve spring seats???????
Post by DanTreace » Fri Jun 14, 2019 5:28 pm
Try first by making a call to the vendors that have lots of used or original parts, Bob's Antique Auto, or Lang's Antique Auto Parts.
Next place an classified free adv. for a set, you might get them that way. Lots of good used ones are out there too, ask for a pile of good used and sort, most have very little wear, some might have cross pin grooves, but cull those away.
Kerry
Last Name: van Ekeren
Post by Kerry » Fri Jun 14, 2019 5:51 pm
Haven't found the replacement new ones to be of a poorer quality for several years.
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Fri Jun 14, 2019 6:55 pm
The major problem inside the last 15 years was the pins more than anything.
Of course, many hobbyists and some engine builders don’t know to turn the spring in the block until the keeper rests level... Failure to do this might result in some odd wear and other “unusual” issues.
Greg Griffin
First Name: Greg
Last Name: Griffin
* REQUIRED* Type and Year of Model Ts owned: '14 torpedo, '25ish pickup
Post by Greg Griffin » Fri Jun 14, 2019 6:58 pm
Hmmm... I didn't know that either. Thanks.
Post by John kuehn » Fri Jun 14, 2019 7:30 pm
Use to find them at swap meets when folks would have cans of T parts to sell. Pretty common to usually find good ones.
Post by Original Smith » Fri Jun 14, 2019 9:51 pm
What is wrong with used ones? I've never seen a worn out one yet!
JP_noonan
Last Name: Noonan
* REQUIRED* Type and Year of Model Ts owned: 1925 Runabout
Post by JP_noonan » Fri Jun 14, 2019 11:15 pm
A few years back i decided to do a complete valve job including new valves, springs, caps and pins. Shortly after, i read here about the questionable spring caps that were causing problems and was worried about it myself. Not sure how long the bad batch was in effect, but i have checked mine on occasion, and it all seems fine so far. Here's an older thread that discusses this problem. Hopefully it has been addressed and all is well. ;)
http://www.mtfca.com/discus/messages/50 ... 1450555390
Experience is a wonderful thing. It enables you to recognize a mistake when you make it again.
