Carburetor Adjusting Rods
Post by Original Smith » Wed Sep 18, 2024 10:57 pm
What year did Ford stop using the forged end carburetor rods? I know they had them through 1914?, but how late after that?
Re: Carburetor Adjusting Rods
Post by DanTreace » Thu Sep 19, 2024 10:20 am
Larry
MTFCI Judging Guideline 7th Ed. has Code # 384, Carb Adjusting Rod noted as having the welded end for 1915 model year.
Earlier were forged ends.
And the design changed to plain bent and flatten end eliminating the knob during the 1916 model year.
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Thu Sep 19, 2024 11:02 am
Pictures would be helpful here, I’m unsure which “carburetor adjusting rods” we’re talking about - the steering column rods, or the under-hood carburetor throttle pull rod ?
Get a horse !
Post by RajoRacer » Thu Sep 19, 2024 11:16 am
I'm assuming the mixture rod.
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Thu Sep 19, 2024 11:40 am
Duh !! Thanks, Steve, I didn’t even think of the forked mixture rod. Still, it would be great to see pictures of the different types, for us shut-ins to see ! :lol:
Get a horse !
Post by DanTreace » Thu Sep 19, 2024 2:00 pm
Here is the early style, forged fork, brass knob, later into 1916 has welded end fork.
Later adj rods all steel looped handle and welded fork. These pics show originals and reproductions, some repro have loop too large to slip into the metal dash slot, rather useless.
Post by Original Smith » Thu Sep 19, 2024 2:07 pm
I don't think a picture would do much good. The weld is difficult to see, where the forged end is welded to the mixture rod. I would really like to see how Ford did this?
Post by Original Smith » Thu Sep 19, 2024 2:10 pm
Not all the forged ends had the number on the forged end. Some do, some don't.
Post by Original Smith » Thu Sep 19, 2024 2:12 pm
Not all the forged ends had the number on the forged end. Some do, some don't. As you can see in Dan's post, the weld is not visible.
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Thu Sep 19, 2024 2:20 pm
Thanks Dan ! I found the pix helpful !
Another interesting detail in the minutiae of T parts !
Get a horse !
hull 433
First Name: Stan
Last Name: Gadson
Post by hull 433 » Tue Oct 29, 2024 8:12 pm
This is the rod that came with the Ghost, welded at the fork. Signs of wear, but not sure if it's original or an older repro.
Post by Original Smith » Wed Oct 30, 2024 11:56 am
The most recent post is on a 1915. The fork is welded on whereas the earlier one posted have the forged ends welded on about 1 3/4" up from the top of the fork. I noticed Ford supplied these rods in 1925 still, and says they fit 1909-25.
