NO LONGER NEEDED! WANTED TO PURCHASE - STEERING GEAR CASE/CUP 1926 COUPE
				lirogo27
- First Name: Lisa
- Last Name: Goldberg
- * REQUIRED* Type and Year of Model Ts owned: Bought my first T - a 1926 T Coupe - in March 2022!
I am located in California.  Willing to pick up locally if necessary.  Looking for a 1926 Steering Gear Case/Cup.  If it comes with cover, I am happy to purchase as set.  Thank you.  Lisa - Please contact me via the forum message center if you d have these items.  Thank you!
				modeltspaz
- First Name: Mike
- Last Name: Spaziano
Re: WANTED TO PURCHASE - STEERING GEAR CASE/CUP 1926 COUPE
Lisa,
If you haven't already, try Mark Chaffin. He often has parts not advertised here on the forum.
Another source would be Lang's. They're a great bunch of people and are always very helpful. Like Chaffin's, they have a good selection of used parts, but you have to contact them by phone.
The third possible source would be Bob's in Loves Park, Ill. He has a very good selection of used parts.
Good luck,
Mike.
Good luck,
Mike.
I should have one. Just bought a Barn load of parts & set aside some steering columns for parts. Will look later today. But if Mark has one take it.lirogo27 wrote: ↑Sun Sep 15, 2024 10:53 amI am located in California. Willing to pick up locally if necessary. Looking for a 1926 Steering Gear Case/Cup. If it comes with cover, I am happy to purchase as set. Thank you. Lisa - lirogo27@aol.com
				ModelT46
- First Name: Darel
- Last Name: Leipold
he will need one from a 1926-27 column.
				lirogo27
- First Name: Lisa
Frank - Let me know!  In error, your reply got flagged and reported.  Darel,  Yes it is a 1926 coupe.  Mike,  Will ask Mr. Lang and Mr. Chaffin but if Frank has the parts I would be happy to work with him. Thank you
				lirogo27
- First Name: Lisa
Let me know! always happy to take it off your hands! Standing by! Lisa Goldberg. Also, if you have the bumpers, happy to buy the same. Thank you much! LisaTRDxB2 wrote: ↑Mon Sep 16, 2024 9:32 amI should have one. Just bought a Barn load of parts & set aside some steering columns for parts. Will look later today. But if Mark has one take it.lirogo27 wrote: ↑Sun Sep 15, 2024 10:53 amI am located in California. Willing to pick up locally if necessary. Looking for a 1926 Steering Gear Case/Cup. If it comes with cover, I am happy to purchase as set. Thank you. Lisa - lirogo27@aol.com
I pulled one out of storage. Need to disassemble, part out, the steering column. Will send you an eMail & if you respond I can send pictures.
The cup looks like its still nickle finish, gears look good & greasy, the cap is in question has barn dust/oil incrustation
				lirogo27
- First Name: Lisa
I sent you an email reply! standing by on the cup and cover. No need on steering column or gears. but let me know what works for you!TRDxB2 wrote: ↑Tue Sep 17, 2024 7:11 pmI pulled one out of storage. Need to disassemble, part out, the steering column. Will send you an eMail & if you respond I can send pictures.
				J1MGOLDEN
- Last Name: Golden
The best way to get the part you need is to look the part up in a Ford Price List of Parts.
Then mention the correct part number in your ad.
That small book is worth the price!
There is no steering gear case cup listed in the book!
Does everyone but me know what part is required?
Then I have only been working with Model Ts for 42 years now!
One old gent told me I can learn something every day, if you pay close attention!
I'm guessing this might be a 3539-D Steering bracket with Bushing.
				jab35
- Last Name: Bartsch
The OP seems to have found the requested parts.  FWIW, p/n 3507 is the "Steering gear internal gear and bushing", p/n 3504 is "steering gear cover", both parts used 09-26 according to1926 Ford parts list.  P/n3539D is "steering gear bracket assembly" for coupe , roadster, tudoor and touring.  jb
All from: https://www.cimorelli.com/mtdl/1926/default.htm
You are correct on all accounts, part numbers and (Lisa) found that parts; being shipping Today, Friday. The knurling on the cover for 1926 is over the entire edge as opposed to the upper half of the edgejab35 wrote: ↑Thu Sep 19, 2024 9:27 pmThe OP seems to have found the requested parts. FWIW, p/n 3507 is the "Steering gear internal gear and bushing", p/n 3504 is "steering gear cover", both parts used 09-26 according to1926 Ford parts list. P/n3539D is "steering gear bracket assembly" for coupe , roadster, tudoor and touring. jb
				jab35
Glad it all worked out.  jb
				J1MGOLDEN
- Last Name: Golden
Case and cover would have been a better description.
				lirogo27
- First Name: Lisa
James - YES IT DID thanks to Frank.  I am floored at how you folks support 'your own'.  Truly very appreciative.  Jim Golden - I was going to list part number from a retailer's current day sales catalogs but I did not think it would matter as part is no longer made allegedly.  Jim has an excellent suggestion and i will locate a reprint copy of the ford list for future.
Jim Golden - JIM !!!!!!- I have sent PM's to you over past few days. Please contact me. You might remember - you sent me a few parts a year or two ago. I have a question for you and sent it via PM on the MTFCA site. THX@ Hope you are well. Lisa
				lirogo27
- First Name: Lisa
Yes but do not need the gears. I should have listed the parts #s but as I said, one is allegedly not made anymore so figured my own unique verbiage would do the trick! LOL. BTW -Replaced the gears recently. I need the other two items. Am thinking mine is worn too much internally causing gears to move and allow play in wheeljab35 wrote: ↑Thu Sep 19, 2024 9:27 pmThe OP seems to have found the requested parts. FWIW, p/n 3507 is the "Steering gear internal gear and bushing", p/n 3504 is "steering gear cover", both parts used 09-26 according to1926 Ford parts list. P/n3539D is "steering gear bracket assembly" for coupe , roadster, tudoor and touring. jb
				lirogo27
- First Name: Lisa
yes 3507 and 3504 are the part numbers. One is still manufactured and one is not.jab35 wrote: ↑Thu Sep 19, 2024 9:27 pmThe OP seems to have found the requested parts. FWIW, p/n 3507 is the "Steering gear internal gear and bushing", p/n 3504 is "steering gear cover", both parts used 09-26 according to1926 Ford parts list. P/n3539D is "steering gear bracket assembly" for coupe , roadster, tudoor and touring. jb
