wtb oil pan ear
robertw413
Topic author - Posts: 26
- First Name: robert
- Last Name: wright
wtb oil pan ear
looking for an oil pan ear late style
Re: wtb oil pan ear
Specify for 3 or 4 dip. They are different.
robertw413
- Last Name: wright
Re: wtb oil pan ear
4 dip but i will make a 3 dip work if i have to
Re: wtb oil pan ear
Once the flange was added to the outer edge of the pan I believe the pan ears were dimensionally the same. I believe the only difference was the later arms were cut square on the bottom. This squared off design came well before the introduction of the 4 dip pan on our Canadian cars.
Re: wtb oil pan ear
I have 4 of #1 ($35each) and one of #2 ($50) plus shipping for any choice
- First Name: craig
- Last Name: leach
Re: wtb oil pan ear
Hi Robert,
Are you looking for a NOS pan ear or a used one? Have you ever removed one before? I took one off of a pan & replaced it with one taken off another pan. Told myself never again! But that was when I had two pans with each with a broken off ear so didn’t have much choice. Someone was making a repair part that welded into a cracked or broken ear to make it strong enough to prevent it from breaking again.
I use the no side bolt & spring on top as in Tinkerin Tips volume II & have had good luck with that method in both the firetruck ( very heavy) & the speedster ( driven like I stole it)
I don’t know anyone that has used the repair ears long term but I keep a set on hand.
robertw413
- Last Name: wright
Re: wtb oil pan ear
i found a set on e-pay and yes i have replaced them a couple of times
