Top damage - needs re-blacking
GJScholz
Topic author - Posts: 65
- First Name: Gregory
- Last Name: Scholz
I have some wear damage on my new top.
Any ideas on how to re dye it?
Boot black?
Has anyone fixes this with long lasting success?
Thank you,
Greg
Boot black?
Thank you,
Greg
Greg Scholz
4th Generation Caretaker
1914 Ford Touring
Survivor Class
http://personal.gregscholz.com/
Esko MN
KD0UYN ‘73
1914 Ford Touring
Survivor Class
Esko MN
KD0UYN ‘73
Rich Bingham
- First Name: Rich
- Last Name: Bingham
Re: Top damage - needs re-blacking
That doesn't appear to be wear damage, rather a smear of some white substance on the top material. Try removing it with a little lacquer thinner (or acetone, your wife's fingernail polish remover) used sparingly on a rag and see if it comes off.
"Get a horse !"
I would start with WD-40 first...you'd be amazed what it will take off without damage to the substrate
- Last Name: Juhl
Did you park under a tree or anger a seagull? Other than that, I'd contact the folks you bought it from and see what they recommend.
- Last Name: Strange
If you find that the white marks are not stains and that you do need to re-color the vinyl, I have had excellent results with SEM vinyl dye products (available at real automotive paint stores). Be sure to use the proper prep before spraying the color.
kmatt
- Last Name: Matthiesen
- * REQUIRED* Type and Year of Model Ts owned: 1926 Coupe, 1921 speedster, 1925 TT, 1916 Exp
Greg, The white marks look like they could be house paint. I would start by using soap and water on a clean rag using light rubbing. If that doesn't work you can try some of the other suggestions, be careful if you try lacquer thinner it could dull the surface of the topping.
GJScholz
- Last Name: Scholz
Its definitely wear.
Thanks cudaman for the tip on the vinyl coloring.
Those cans look expensive.
Greg
Greg
Greg Scholz
1914 Ford Touring
Survivor Class
Esko MN
KD0UYN ‘73
1914 Ford Touring
Survivor Class
Esko MN
KD0UYN ‘73
Inthegarage
- Last Name: Mosher
- * REQUIRED* Type and Year of Model Ts owned: 1927 Roadster pick up
I’ve had good luck with black shoe polish. Rub it in and wipe it off.
Jeff Perkins
- Last Name: Perkins
Greg, I also have had success using shoe polish for cosmetic top and boot repair.
1926 Model T Touring,
1948 Chrysler New Yorker,
