Anyone have a working low radiator sitting around? I’m in northern IL and my 1919 needs a little better one.
Thanks,
James
Wanted: Low Radiator
Re: Wanted: Low Radiator
Might wanna consider sending it to your local radiator shop over the winter and having it re-cored or maybe even just boiled out. When my original round tube rad sprung a leak where the overflow tube fits on the tank showed up, taking the rad to the shop was the best thing I did. They boil 'em out as a normal procedure and wow, now it cools like no tomorrow! A mere $85 repair job just gave me a "new" $900+ radiator!! It seldom has the red stuff of the moto meter reach the "open circle" on a 90 degree day.
Joe Bell
- First Name: Joe
- Last Name: Bell
I have one that i use on my test stand, needs a little solder on the top neck from pin holes.
Fozz71
Topic author - Posts: 280
- Last Name: Chochole
- Board Member Since: 2003
Joe, my radiator is pretty beaten up and although it holds water, I do think it is time for an upgrade. Can you message me and we can exchange details? Thanks!
