Bolts
Bolts
Post by Original Smith » Sat Oct 26, 2024 11:45 pm
Is anyone making the correct 1/4-28 engine dust pan bolts. These were used on the brass radiator cars.
First Name: Keith
Last Name: Townsend
Re: Bolts
Post by KWTownsend » Sun Oct 27, 2024 12:14 am
No.
The heads are 3/8" square. Different years' parts books list different lengths.
Re: Bolts
Post by Allan » Sun Oct 27, 2024 6:56 am
I know of three different lengths. The front ones are 1/2" longer on the cars. Then there was an even longer one for the rear on the deeper frames of the TT's. All have a smaller head than a standard hardware shop bolt of today. A few I have seen do not have the four pointed square under the head. Instead, they have just two points. All have used a larger square nut than those found on later general hardware. Now square nuts are made of unobtaineum.
Re: Bolts
Post by Original Smith » Mon Oct 28, 2024 12:01 pm
One thing has hasn't been mentioned is the little bolts have a cotter pin hole through the bottom.
First Name: Keith
Last Name: Townsend
Re: Bolts
Post by KWTownsend » Tue Oct 29, 2024 3:23 pm
From the 1912 catalog:
1/4" x 9/16" quantity: 7
Here are some that I believe Richard Eagle made:
Here is from the 1916 catalog:
3088B 1/4" x 3-1/4" quantity: 2
3088C 1/4" x 3-5/8" quantity: 2
