Instructions for Midget Glo-Lite
WorldChamp1914
Topic author - Posts: 402
- First Name: Gary
- Last Name: Hagen
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring and a 1921 Sightseeing Bus.See SF On a Dime
I have a NOS Midget Glo-Lite but no instructions……does anyone have the original instructions or maybe photos, did it come with a switch?……Thanks Guys!
Re: Instructions for Midget Glo-Lite
This link has some similar & had this ad https://www.mtfca.com/discus/messages/1 ... 28288.html
I'd guess it had no switch. You could connect it to either of the headlight terminals on the firewall terminal strip so that it would come on when either the high or low beams were turned on, or to the tail light wire, so that it would come on whenever the lights were switched on. Earlier cars with magneto lights would require a different approach, I'd think.
Since its an indicator if the "headlights lights are on" then wire to the taillight post on the terminal block. That way it would be turned on when the switch was in the DIM or ON position for headlights. If just "Headlight" as in "not DIM" then to the #6 position (says Bright in the diagram) on the terminal block.
WorldChamp1914
- First Name: Gary
- Last Name: Hagen
Thank you very much!
ModelT46
- First Name: Darel
- Last Name: Leipold
MOTO-LITE was another brand of the same device. I have a NOS one in the original box Here are two photos.
WorldChamp1914
- First Name: Gary
- Last Name: Hagen
Wow…..thanks
WorldChamp1914
- First Name: Gary
- Last Name: Hagen
How can I replicate the cord part?…….Do you have any closeups of the metal sheath?
WorldChamp1914
- First Name: Gary
- Last Name: Hagen
How long is it?…..Were there any installation instructions?
WorldChamp1914
- First Name: Gary
- Last Name: Hagen
I see it now, 5 feet long. What does the end look like?…..Thank you very much!
ModelT46
- First Name: Darel
a steel braided cable. a fitting to fil the moto lite. No fiting on the other end. I once h ad about 10 of these. None hade any instructions. I assume then you woukld need to install an fiting on the end that goes to you lighting system.
WorldChamp1914
- First Name: Gary
- Last Name: Hagen
