Hi all,
Funprojects used to carry CORRECT hood springs but since they are gone, I did not see them on birdhaven or others. Or has anybody found a part substitute readily available to order that works better than the standard supplier ones? Thanks
Fun projects hood shelf springs- who carries now?
Will_Vanderburg
- First Name: William
- Last Name: Vanderburg
Re: Fun projects hood shelf springs- who carries now?
The only way to know if they have them is to call them. Their catalog, which I have, does not identify products that were formerly made by others
William L Vanderburg
1922 Center Door Sedan
My 14 year old son made a compressor to fit the ridiculously stiff springs offered by the vendors at the time. These put way too much load on an aluminium hood, so I replaced them with much lighter gauge ones from a hardware shop assortment. They are still in use after decades.
- Last Name: Strange
I second Allan's recommendation. The stock hood hold down springs on my 1912 Flanders were even stiffer than the Model T springs, so I replaced them with some weaker springs from the hardware store, they work great.
Bmettli
Topic author - Posts: 87
- First Name: Brian
- Last Name: Mettling
- * REQUIRED* Type and Year of Model Ts owned: 1922 touring, 1933 Dodge
Yes, I got replacement 2 inch spring from Menards today for around $1 each. Much better
