Clutch Fork, what would cause this problem?
Rata Road
First Name: Kevin
Last Name: Weeds
* REQUIRED* Type and Year of Model Ts owned: 1923 Depot Hack, 1927 Coupe & 1914 Runabout
Post by Rata Road » Fri Nov 15, 2024 8:23 pm
I'm posting this on behalf of a friend who lives too far for me to view. He has the Hogs head off and is in the process of relining his bands and found this.
Causes and fix ideas would be appreciated.
[attachment=0]Murrays Clutch pic xx.png[/attachment]
Re: Clutch Fork, what would cause this problem?
Post by Wayne Sheldon » Fri Nov 15, 2024 9:14 pm
The hose clamp was probably put on the shaft in a failed attempt to prevent the shaft from pushing too hard to one side.
Several things can cause the shaft to push to one side or the other. Bent. worn, or otherwise damaged clutch cam, levers, or linkages can put quite a lot of pressure one way or the other.
Simply installing the linkage between the low pedal and clutch shaft can put quite a bit of pressure. Another cause can be not having the matching offset (starter and non-starter) pedal and clutch shaft.
The "L" and "fork" link between the pedal and clutch shaft arm can often be flipped around to improve lining them up a bit. Sometimes arms need to be bent to get them near right.
Post by Allan » Fri Nov 15, 2024 9:18 pm
I"d be checking to see if the rivets holding each arm are tight. It looks like on is loose on the shaft, allowing / making the other
To do all the work.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Fri Nov 15, 2024 11:18 pm
Some aftermarket clutch packs ( early Watts perhaps) were sold many years ago with a round wire high speed clutch spring from a modern automatic transmission (Buick?) that was just a tad bit too large in diameter and those would rub on the clutch fork arms. Just something to check.
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Sat Nov 16, 2024 8:19 am
If he has a spring, washer, and o ring on the outside to “seal” the shaft, that is what caused it.
Rata Road
First Name: Kevin
Last Name: Weeds
Post by Rata Road » Sat Nov 16, 2024 6:47 pm
Thanks guys, I will pass on your thoughts
Post by Allan » Sun Nov 17, 2024 6:39 am
I missed the hose clamp when I looked. It may well have been fitted to mask a problem. The L linkage between the clutch shaft and the pedal can cause unnecessary load, especially if the eyes have been rebuilt and drilled back to size to neatly fit a new linkage. The pedal needs to move sideways when operated. A neatly fitted L linkage will not allow it to do so without adding tension within the system. It is one place where absolute precision works against you. There needs to be a little 'slop' to allow the pedal to move sideways.
