Ford 5Z323 starter drive gear puller, excellent, $95.00.
Ford 5Z1172 wire wheel hub puller NOS $225.00.
KRW drive shaft pinion gear puller $200.00.
KRW Slocume setting fixture $200.00.
Ford 5Z1900 model A and B crankshaft ratchet nut wrench $125.00
KRW Flywheel housing indicator for model A. Also is an excellent tool to mount on the end of the T crankshaft while rebuilding an engine.$150.00.
2 vintage wood handle hacksaws, $25.00 each.
All plus shipping. kdmks AT att.net.
FS KR Wilson and Ford tools
KimDobbins
Topic author - Posts: 1723
- First Name: Kim
- Last Name: Dobbins
KimDobbins
- First Name: Kim
KimDobbins
- First Name: Kim
Re: FS KR Wilson and Ford tools
All tools are sold except for hack saws and flywheel indicator.
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
The flywheel tool is real handy to use while assembling an engine and setting valve lash.
