WTB fork mounted license plate bracket
havnfun
Topic author - Posts: 479
- First Name: Joe
- Last Name: Kowalczyk
Howdy,
I’m looking for a brass era headlight fork license plate mounting bracket.
Regards,
Re: WTB fork mounted license plate bracket
Joe, there was one which bolted around the headlight stalk on the electric headlights. It may be the same as the one you are searching for.
There are two that I am aware of
#871 for pre 1915 (2nd down on the left) --
#440 no picture but this has been reported for Canadian Models
Frank, that Canadian one is the one I recall. It should fit all single stork light mountings.
Looks like the Neverout #440 isn't the same as the Canadian mount & could be made quite easily
Could be a DIY
Could be a DIY
havnfun
- First Name: Joe
Still looking….
Regards,
big2bird
- First Name: Jeffrey
- Last Name: Hausey
Only one I ever found. Good luck.
Colin Mavins
- First Name: Colin
- Last Name: Mavins
The bracket pictured clamped to the fork is on my 1912 touring it was on the car in 1960 a complete running car my thought is it is from 1915 or later because the early Manitoba plates are short that is why there is an extra hole so I can put the 12 plates on the car . It is an original Winnipeg Manitoba Canada car built in Walkerville Ontario.
Colin Mavins
- First Name: Colin
- Last Name: Mavins
I stand corrected I found a ad from 1913 specialty auto parts New York NY states it will fit all fords form 1911 through 1913
Colin Mavins
- First Name: Colin
- Last Name: Mavins
This ad is from 1914 so they are a US item there should be loads of them out there Cheers Colin
