1915 headlights
				johnr
- Last Name: Delamater
- * REQUIRED* Type and Year of Model Ts owned: 1927 Depot Hack
1915 headlights
Looking for a pair of headlight for 1915 .
Will need assemblies including forks.
Thank you
Thank you
- First Name: Keith
- Last Name: Townsend
Re: 1915 headlights
John,
Unless you have an early Canadian car, headlights for 1915 do not use separate forks. The bucket and mount are all one part. The focus screw is above the socket. The lens is clear, not fluted.
				johnr
Re: 1915 headlights
Thank you Keith for the information.
Along with this does anyone have a pair of 15 headlight assemblies or decent buckets that they are willing to part with ?
				Fozz71
- Last Name: Chochole
- Board Member Since: 2003
Re: 1915 headlights
I believe some early '15's did indeed use leftover "forks" from the 1914 models. But fairly early on they switched over to standard posts.
				johnr
Re: 1915 headlights
Okay does anyone have any 15 headlights out there forsale ?
				Larry
- Last Name: Gresh
Re: 1915 headlights
I have several sets John.
What condition are you looking for?
				johnr
Re: 1915 headlights
Larry
The more complete the pair would be better.
Could you contact me so that I can get info to call you ?
John
John
				Larry
- Last Name: Gresh
Re: 1915 headlights
John,
Sent you a private message with contact information.
Let me know if you have not received it.
Larry
Larry
				johnr
Re: 1915 headlights
Larry
did not recieve your message
John
John
