Block Machining
Jeepbone1
First Name: Brad
Last Name: Kirtner
* REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
Block Machining
Post by Jeepbone1 » Thu Jan 17, 2019 9:34 am
Due to the heating process of pouring Babbitt, is t best to machine the cylinders and deck surface before or after the Babbitt is poured? I can think of reasons to justify both ways but what's more widely accepted?
Kerry
Last Name: van Ekeren
Re: Block Machining
Post by Kerry » Thu Jan 17, 2019 3:12 pm
Heating the bearing saddles for babbitt doesn't require a temp that would efect the cast iron. My cylinder boring bar is a Repco, same as a van Norman and uses the saddles for clamping, so bore before pour, although I did make a clamp for it to do when babbitt isn't going to be replaced.
Re: Block Machining
Post by Allan » Thu Jan 17, 2019 4:43 pm
I have mine bored prior to pouring the bearings, but leave the final honing until after the bearings are poured, mainly to ensure all is clean before building.
