Metal strip that goes across the bottom of the top
				Kbillet
- First Name: Keith
- Last Name: Billet
The 15 has a steel round that fastens the rear of the top to the body. Anybody have an idea as to where to source the material?
- First Name: Keith
- Last Name: Townsend
Re: Metal strip that goes across the bottom of the top
Is this what you are looking for?
Compound curves are tricky...
Touring or runabout?
jsaylor
- Last Name: Saylor
See a possible product on this speedster site.  https://www.facebook.com/groups/496619540483459.  Scroll to James Starkey post.
Taco Marine and Restoration Supply.
				Kbillet
- First Name: Keith
- Last Name: Billet
Thank you Jsaylor. It looks like a likely solution
In the meantime, you could use a length of trim strip and upholstery nails. Hidem binding is a bit late to be using on an early car.
