WTB for 25 Touring
Ed Baudoux
First Name: Edward
Last Name: Baudoux
WTB for 25 Touring
Post by Ed Baudoux » Sun Dec 08, 2024 7:56 pm
Coil Box, Ignition and headlamp switches, Mag Ring, flywheel with magnets. I'm returning a car to original configuration. Grayling Michigan.
Grayling Michigan
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
Karl Von Neumann
First Name: Karl
Last Name: VonNeumann
Board Member Since: 2022
Re: WTB for 25 Touring
Post by Karl Von Neumann » Tue Dec 10, 2024 1:03 pm
Shoot my and email I've got coilboxes and ignition switch I've also got the rest but would be very heavy to ship I'm in south east wi
Post by Mark Gregush » Thu Dec 12, 2024 8:31 am
Unless the holes for the screws holding the ring gear/flywheel have been enlarged, it would cost less to buy a set of magnets, clamp plates and mounting bolts then order the new brass screws and support spools from the suppliers. If you are going thru all this work, suggest NOT putting an old crusty failing mag plate it and get recharged magnets. Suppliers have those too.
