22 sedan. Slow work
Will_Vanderburg
First Name: William
Last Name: Vanderburg
22 sedan. Slow work
Post by Will_Vanderburg » Tue Dec 17, 2024 10:58 pm
Here’s the oil pan that goes with the 22 dated engine I bought at Luray. I bought the block with pistons, crank, cam and head plus this pan for $100
I used an inspection cover I redid from Hershey, and replaced one pet cock and the wishbone studs from my stash of parts.
The cover is really shiny from a spray bomb, sanded between coats.
William L Vanderburg
1922 Center Door Sedan
Dave Young
First Name: David
Last Name: Young
* REQUIRED* Type and Year of Model Ts owned: 26 Touring, 26 RPU, 24 Coupe, 26 Speedster, 28 Chandler, 29 Chandler, 29 A
Re: 22 sedan. Slow work
Post by Dave Young » Fri Dec 20, 2024 11:12 am
Looking good!
Post by Wayne Sheldon » Fri Dec 20, 2024 5:29 pm
Progress is good! Even if it is just a little progress.
Post by John kuehn » Fri Dec 20, 2024 6:41 pm
A little here and a little there. It takes time but well worth it. Pretty soon you’ll have the chassis together. How is the babbitt in the block. Sometimes but not often blocks show up with pretty good babbitt. Use to find those years ago but not real often these days.
Will_Vanderburg
First Name: William
Post by Will_Vanderburg » Fri Dec 20, 2024 7:43 pm
I haven’t checked yet but that’s next on the list. I completed the parking brakes on the chassis earlier this month.
