WTB Rain Gutter without Drip Edge
adam13
First Name: Adam
Last Name: Eyre
* REQUIRED* Type and Year of Model Ts owned: 1915 Speedster, 1918 Touring, 1922 Roadster
Post by adam13 » Sun Dec 15, 2024 4:45 pm
Want to buy 2 rain gutters for firewall without the drip edge. Contact AJ or Mark Eyre through the forum.
Re: WTB Rain Gutter without Drip Edge
Post by RajoRacer » Sun Dec 15, 2024 5:08 pm
Please explain "w/o drop edge" - I have a wood firewall top gutter piece.
Post by Allan » Mon Dec 16, 2024 5:53 am
Our Canadian sourced cars with a wooden firewall came with thin [think tinplate] metal cover on the sides, from the relief for the hood hinge down to the bottom. This was nailed on and the hood lacing was nailed over the top of it. Are you looking for a similar piece to go across the top, without the rain gutter? I can't recall ever seeing one.
Model T Mark
Last Name: Eyre
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring 1914 Touring and Roadster 1915 Touring 1926 Roadster
Post by Model T Mark » Tue Dec 17, 2024 6:10 pm
He took a picture last night but he has basketball till late each night this week so as soon as he can he will.
adam13
First Name: Adam
Last Name: Eyre
Post by adam13 » Wed Dec 18, 2024 12:01 pm
Here is a picture of one. Sorry to all for slow responses as I’ve been very busy coaching and starting building a house this week. Thanks, AJ Eyre
Post by Allan » Wed Dec 18, 2024 4:39 pm
Adam, thanks for the photo. I have never seen the like. Perhaps you would have what you need by cutting the rain gutter off a later one. On our Canadian sourced cars there is a crescent shaped relief in the wooden firewall to accommodate the hood hinge rod. I can't see this in your photo. Our rain gutters terminate at this relief, and short separate sections finish off the firewall down each side.
Post by RajoRacer » Wed Dec 18, 2024 5:02 pm
This is what mine looks like.
Post by Mark Gregush » Thu Dec 19, 2024 9:11 pm
yup, parts book does show sides and top.
Post by Allan » Thu Dec 19, 2024 11:29 pm
The metal will shed water. It likely there to protect the edges of the wooden firewall/veneer from water ingress. On our Canadian cars the top cover with the rain gutter had holes drilled and the nails which held the welting also held the rain gutter piece in place, with the addition of a screw into the side of the piece at the centre under the hood centre hinge rod. The bits of tin on the lower sides were not drilled. The nails which hold the welting on also held the thin metal strip in place.
Post by Jerry VanOoteghem » Sat Dec 21, 2024 9:57 am
Yes, but they're not all like that.
Post by Jerry VanOoteghem » Sat Dec 21, 2024 10:02 am
Adam/Mark,
This piece was missing on my '21 Runabout. Most of them are, because they were made of a thin, cheap piece of tin and they simply rusted away. Good news is, however, they are made of a thin, cheap piece of tin! For my car, we used tin strip of the proper width, and just turned over the edges. The edges are fairly narrow, which also makes it easy to form. You could do it over a seperate form or possibly just form it in place, on the firewall.
It's in 3 pcs., correct? A top piece and two side pieces, with a gap in between to clear the hood hinges? (My car is not on-site to have a direct look, or take pictures.)
Last edited by Jerry VanOoteghem on Sat Dec 21, 2024 2:38 pm, edited 1 time in total.
Post by RajoRacer » Sat Dec 21, 2024 10:44 am
Thanks for the additional info - not seen one without the gutter.
Post by Mark Gregush » Sat Dec 21, 2024 11:48 am
I should re phrase what I wrote, the parts book (1921) list them but does not show them. Also does not say gutter type or not. Unlike later, parts numbers didn't change by adding a letter after them like became the norm later.
Post by Allan » Sat Dec 21, 2024 10:56 pm
I would be taking up the one Steve has offered. The thing is more complicated than it looks. Because it is angled at the ends to follow the taper in the hood sides, it becomes three dimensional rather than just a flat piece with folded edges. The one he shows is a pressing, with the correct angled ends. It just needs the gutter cut of and that bit of centre bracket added. It is likely of somewhat heavier gauge metal than the tinplate side pieces.
Post by RajoRacer » Sun Dec 22, 2024 9:22 am
The center bracket is on the other side !
Post by Jerry VanOoteghem » Sun Dec 22, 2024 11:05 am
Allan,
Is that how the gutterless trim piece was made on your car?
Good luck Adam.
