Holy COW!! this is by far the single biggest improvement so far. My 1/2 mile hill up to my house is a killer. I've had to use low Ruckstell/low band every time the entire way - even if I make a run for it. That's until last night when I was able to climb it in high Ruckstell/low band the entire way at low RPM/speed with no struggle.
This is the last in a series of upgrades after the 280 cam, aluminum pistons, Zenith carb & distributor. All that and all you fine fellas still call this a "stock engine". I guess I'm going to have to adopt that vocabulary term even though it goes against every known norm, at least in the racing world which states "if it's not the same as it came off the factory assembly line, it ain't "stock"!!!
I think I'm going go stop here on the motor mods... Sorry Robert Weitzel & Eric Barrett. No Wild Cherry for me!
I am still thinking about changing my large drum Rocky Mtn brakes for something that will hold me in a stopped position on my hill vs certain death. Still not sure which way to go there. I really wouldn't like the look of the disc brakes on this "stock car"
AdminJeff
