WTB Steven's front axle yoke resurfacing tool
Jack Putnam, in Ohio
Topic author - Posts: 497
- First Name: Jack
- Last Name: Putnam
I am searching for the Stevens Front axle facing tool that is used
to reface the inside yoke surfaces. The inside surfaces of the front axle yoke wear and this tool is used to file them perpendicular to the king pin. Please contact me through the forum email. Thank you, Jack[
RGould1910
- Last Name: Gould
Re: WTB Steven's front axle yoke resurfacing tool
Heres the tool I use. Got the idea from Dan Hatch.
- First Name: Jack
- Last Name: Putnam
Richard, thank you for your reply. I am hoping to remake the original tool, I am not trying to repair an axle. I believe I made the Steven's tool you show in your picture
Pep C Strebeck
- First Name: Joseph
- Last Name: M
Jack,
If you do make the tool for sale like your Reaming Fixture Frames, I will definitely buy one, not just saying' I'll even pre-pay. I use a reverse spot-facer and it works, but an original or quality reproduction would be very much appreciated. Here are a couple of photos from the Forum showing it in use (for those not in the know) and a link to a complete axle rebuild. As far as I know it is not shown in the Stevens catalog.
viewtopic.php?f=2&t=26080&p=200399&hili ... le#p200399
dobro1956
- First Name: Donnie
- Last Name: Brown
Jack. The photos posted above are my refacer. I may have the only one left ??. I have never seen another. I do not want to sell mine, but would consider a short term loan if it would help you getting them made. I use it fairly often so it can only be loaned for a short time. The main issue I see is the cutter is extremely hard. Properly making it would be the key to having a useable tool. It really does not "cut" as it re-faces but "scrapes" the surface smooth. It makes extremely fine shavings and must be cleaned very often as it's being used. The cam and the handle would also need to be very hard because they are under a lot of pressure when in use. But they probably are not as hard as the cutter. Send me a message if you want to discuss it.
TrentB
- First Name: Trent
- Last Name: Boggess
No, there are at least two survivors. This one is NOS.
- First Name: Jack
- Last Name: Putnam
Trent: I have sent you an email . Jack
- First Name: Jack
- Last Name: Putnam
I'm still searching for this Steven's axle tool. Can anybody help me find one??
Search "Used my rare Stevens front axle re-facer today"
Donnie Brown posted a dimensioned drawing of the tool you seek.
I reproduced one from it. Thanks Donnie.
If you reproduce parts, I would be interested in a cutter. I didn't get a proper hardening on mine.
- Last Name: Tannehill
- Board Member Since: 2002
John can’t you reharded the piece and then temper it again?
- First Name: Jack
- Last Name: Putnam
I'm still searching for this tool.
- First Name: Jack
- Last Name: Putnam
Well the need continues as well as the search.
Still searching .
Still searching .
- First Name: Jack
- Last Name: Putnam
And the search continues. There must be a survivor available somewhere.
