Thin wrenches
Moxie26
Last Name: Jablonski
Thin wrenches
Post by Moxie26 » Mon Feb 17, 2025 11:17 am
What would be a good source for thin wrenches... Example holding a post nut while tightening the cable nut on a starter switch.
jab35
Last Name: Bartsch
Re: Thin wrenches
Post by jab35 » Mon Feb 17, 2025 12:00 pm
Amazon has many choices, for example: https://www.amazon.com/Erwachte-Super-T ... r=8-9&th=1
Not a recommendation, just made a search. EBay would likely have them too. Best, jb
Dennis Prince
Last Name: Prince
Re: Thin wrenches
Post by Dennis Prince » Mon Feb 17, 2025 12:06 pm
Thin wrenches are called tappet wrenches and since they are not very strong, what I do is take a cheap wrench the size that I want and use the belt sander and slowly make it the thickness that I want. Don't let it get to hot and it won't take out the temper.
kevinf
First Name: Kevin
Last Name: Fielding
Re: Thin wrenches
Post by kevinf » Mon Feb 17, 2025 12:55 pm
Robert,
As was mentioned, they are called tappet wrenches. I just recently purchased a set of Craftsman off e-bay.
A quick search and I think you will find what you need,
Hope that helps,
Kevin
Re: Thin wrenches
Post by Allan » Mon Feb 17, 2025 4:59 pm
I do as Denis does. The other place a thinned down wrench is useful is when adjusting T model accessory adjustable tappets.
Until I found two different stubby 9/16" ring spanners I used a pair of shortened, thinned down ring spanners on carburetor mounting bolts.
Last Name: Patrick
Re: Thin wrenches
Post by jiminbartow » Mon Feb 17, 2025 10:32 pm
Go to Www.McMaster.com and search tappet wrenches.
John.Zibell
Last Name: Zibell
Re: Thin wrenches
Post by John.Zibell » Tue Feb 18, 2025 9:25 am
For that task, I gut a slot in the post with a dremel, then hold the post with a screw driver to tighten the nut.
1926 Tudor
Erik Johnson
First Name: Erik
Last Name: Johnson
Re: Thin wrenches
Post by Erik Johnson » Tue Feb 18, 2025 11:53 am
While it is true that tappet wrenches have a thin profile, you don't have to limit yourself to tappet wrenches.
Just google thin wrench set, super thin wrench set, thin wrenches or thin profile wrenches and will find a good selection.
Moxie26
Re: Thin wrenches
Post by Moxie26 » Wed Feb 19, 2025 9:20 am
Thanks everyone for your help and suggestions... A nice set was just picked up on eBay.
