For Sale: Used ring and pinion gears.
Ford script ring gear.
11-40
$75 plus shipping
Pending ring and pinion
Topic author - Posts: 500
- First Name: Clay
- Last Name: Atkins
- * REQUIRED* Type and Year of Model Ts owned: 1921 Roadster
- First Name: Clay
- Last Name: Atkins
Re: FS ring and pinion
to the top
- First Name: Ken
- Last Name: Buhler
- * REQUIRED* Type and Year of Model Ts owned: 1927 Roadster 1927 Coupe
- Board Member Since: 2012
Hello Clay,
I'm curious. You should clean them and show some closeup shots of what matters to buyers. Like the wear areas, or the factory tooling marks showing little or no wear. This might be why you have had no replies. The burrs on the crown gear make it look unusable.
Work honestly
Stay true to your word
Get the job done right
