Rear main adjusting with a 3 dip pan
Topic author - Posts: 667
- First Name: Bruce
- Last Name: Compton
- * REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
I'm thinking about taking some main shims out and was wondering if there are any tricks to get at the rear main cap in my '21 with a 3 dip pan. I've done this many times,but always had a 4 dip pan. Thank's : Bruce
- First Name: Gene
- Last Name: Carrothers
Re: Rear main adjusting with a 3 dip pan
I've taken a shim out of the 4th rod but don't think you can access the rear main. The rod was tricky enough and I have good hands for tight work. Make sure you stuff plenty of numbered rags in if you go there!!
1912 Torpedo Roadster
- Last Name: van Ekeren
Like Bruce has posted, hard enough just to do #4 rod let alone take 2 fly wheel bolts out to drop the cap, and re-wire etc,
maybe some has done it, would sure like to know if possible.
Sorry, as Gene has posted.
