Installing a new 280 camshaft into a 26 engine.
Apparently someone had installed an earlier cam ( pre 24 style) as it has the longer front bearing,…. Not a huge issue as I can cut the bearing to the required length on my lathe.
This engine engine was rebuilt recently, so I am going to try and re use the bearings. The location pins for the bearing are really sloppy in the holes in the bearings, so I will build them up and resize them.
Question,…. Does the thrust surface on the camshaft ride on the front of the engine block, or the front of the cam bearing?
I pose this question because on this engine the front cam bearing, when installed is about .010” behind the front the block,
Dave
Camshaft endplay
Re: Camshaft endplay
RE the building up of the hole: Depending on how you do that, heat can melt the thin coating of babbitt and at minimum you may need to ream the bearing when done.
Dave1
Topic author - Posts: 109
- Last Name: Eddie
- * REQUIRED* Type and Year of Model Ts owned: 1926 Tudor, 1926 Touring, 1931 Plymouth PA, 1952 Hudson Hornet
I will build up the OD of the anchor pin, then machine it to fit the hole in the bearing.
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
The front thrust surface is the face of the bearing, not the block. The bearing face should protrude from the block face If that is not the case, then I suggest you get a different front bearing.
Dave1
- Last Name: Eddie
Got it, thanks
