TT rear axel worm drive
Jmeinert1@wi.rr.com
Topic author - Posts: 1
- Last Name: Meinert
Looking for a TT rear axel worm drive complete
tom_strickling
- First Name: Tom
- Last Name: Strickling
- * REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 18 Touring, 21 TT Huckster, 24 Roadster,snowmobile, Shaw tractor conversion
Re: TT rear axel worm drive
Do you just need the worm and the ring or a complete rear end??
“The trouble with retirement is that you never get a day off.” – Abe Lemons.
HPetrino
- First Name: Henry
- Last Name: Petrino
A couple of thoughts as you shop for a rear end:
They are not all the same. Early TT rear ends have a bead on the clam shell at the axle tube opening, later ones do not. Early TT rear ends have a differential shaft with two differential gears, later units have a differential spider with four gears. Early units have a plain axle housing cap, later units have a hole and plug. Also, there are two stock gear ratios, 5 1/16:1 (slow, harder to find) and 7 1/4:1 (slower, easier to find).
So, the point is be sure to get what you really want. Getting one that works is probably not too difficult, getting a specific set-up might be a little more challenging.
Good Luck!!
Good Luck!!
Burger in Spokane
- First Name: Brent
- Last Name: Burger
- Board Member Since: 2014
Putting Henry's comment into perspective, a 7:1 ratio gear set will have your engine
maxed at 20mph. Even slower if it is not rebuilt and balanced. A rebuilt and balanced
engine with a 5:1 gear set will do a comfortable 35 and have an upper end approaching
50. While the gear set is an important consideration, Model T engines were not balanced
at the factory - road conditions limited speed to a level that made doing so a waste of
money - so now, when we drive them on nice paved roads, we discover just how unbalanced
those engines were when we get them up to speeds they were not exposed to in pre-war days
and try to shake themselves apart going down the road.
Erik Barrett
- First Name: Erik
- Last Name: Barrett
- * REQUIRED* Type and Year of Model Ts owned: 1913 speedster 1924 touring 1925 dump truck
What Burger said. Unless you are doing nothing but parades, you want the high speed gear set.
- First Name: Adrian
- Last Name: Whiteman
One other thing to remember is the size of tires you use!
Some have taller side walls - they effectively increase your final ratio over the road compared to lower side wall heights.
A club member with the same worm ratio as mine, but with lower height side wall tires actually went faster than me over all as he went up hills quicker ! …
