What parts are coming to Duncan?
- Last Name: Hatch
Why don’t you guys going to Duncan post what you’re bringing?
Might help talk someone into going.
				Mike Lebsack-Iowa
- First Name: Mike
- Last Name: Lebsack
- * REQUIRED* Type and Year of Model Ts owned: 11Torpedo, 11 Roadster, 13 Touring, 14 Roadster, 14 Touring
- Board Member Since: 2008
Re: What parts are coming to Duncan?
I am bring a new pair of 17-25 rear fenders for roadster or pickup with all the correct mounting brackets. I will price them well below catalog and there will be no shipping costs at Duncan. Nice pair of large 6 bolt rear brake drums. Lots of unrestored 13-14 J.Brown sidelights, several 1914 windshield frames complete. A couple Russ Potter restored brass carburetors that have not been used. Lots of good, mostly brass era miscellaneous T parts. If there is something in particular needed I can bring them.
				Gene_French
- First Name: Gene
- Last Name: French
- Board Member Since: 2014
in addition to my babbitt bearing tools i will be bringing a pair of 26/27 model T 4dr. front doors , sets of re-babbitted T connecting rods sized Std. , -.010",-.020" and -.030" sizes also several individual re-babbitted rods of various sizes including 1 heavy rod at -.010 diameter, re-babbitted T ballcaps in Std., -.002" and -.004" and -.010" sizes ... Atwater-Kent LA distributor , Bosch distributor , Simms-Huff starter generator ( Maxwell) ... some Dodge Brothers distributors , carburetors, radiator caps, distributor rotors and early Delco distributor cap ...Dixie and Wico magnetos ...will be looking for 20" 5lug Dodge Brothers disc wheels and Masonic automobilia items from 1900-1940 ...Gene French
				Mike Lebsack-Iowa
- First Name: Mike
I will also be bringing a brand new, never used, Model A high speed ring and pinion set that I will sell significantly below the catalog price. Please contact me with a PM if you want more detail. Mike
- Last Name: House
That’s a good idea Dan. I’ve been selling T parts on a mail order FedEx, USPS bases for a few years but am now bringing larger, difficult to ship parts to Duncan. I’ll have a real nice pair of 17-23 front fenders $120-$130, nice extra LF 24-25 fender, round gas tank with straps and cap $90, very good pair rear open T fenders w/ one xtra RR fender $80, set of mid 20s splash aprons $90, really nice demountable Round spare tire carrier $100, rear taper leaf spring $200. Many smalls. Stop by inside close to Tannehill and French. Save on exorbitant shipping.
- Last Name: Hatch
George: That round carrier is a fairly rare item. Made just for Kelsey lugless rims.
dobro1956
- First Name: Donnie
- Last Name: Brown
I'll have a Rajo head with exhaust project, a Wakasha Ricardo head, some NOS small goodies. Some neat period camping gear,  Just lots of stuff.
Added a big tub of speedometer stuff. Lots of different makes, models, and years of speedometer parts.
- Last Name: House
I have 2 left sides ‘23-‘25 touring TOP SOCKETS in great condition. Does anyone have 2 right side TOP SOCKETS they’d want to trade one ? If so, I could bring them to Duncan for your choice.
- Last Name: Tannehill
Early T brass lamps, headlights, 09-mid-10 5 ball carb, Small reproduction Jno Brown generator, E&J reproduction Generator, full set of Victor Model (1)Headlights, side lights & tail light. Double twist Rubes & NonPareil horns, Sears & Curve dash Olds horns & a bunch of other stuff.
If there is an interest I can bring a 1911 split valve block, a 1912 also a 1914.
- First Name: Keith
- Last Name: Townsend
If anyone sees a Frontenac exhaust manifold like this:
or this design, without the preheater:
while you are at Duncan, please let me know!
Keith
Keith
				Gene_French
- First Name: Gene
- Last Name: French
i have added a model B crankshaft , a 28 chev. 2 port cylinder head , chev. crankshaft and a pair of cast aluminum lowering brackets for the rear crossmember of a model T speedster ... will be adding items as i dig deeper in my pile of stuff ...see you all at the Duncan swapmeet ...Gene French
				Gene_French
- First Name: Gene
- Last Name: French
have added a new , never installed Prus aluminum cylinder head to my pile of stuff ...also 1 minus .015 diameter connecting rod per customer request ... i will have some time to machine ball caps to special dimensions as needed ... i will have a good supply of common dimension ball caps and connecting rod sets onsite ... also a few single connecting rods ...see you all there ...Gene French
- Last Name: House
MORE: restored 16” and 17” fordite steering wheels w/ black powdercoated spiders $80-$120, used early transmission brake drums $35,and many Ford O tail lamps for trucks $65-$80, early and late front motor mounts $40, pair accessory bolt on ‘ears’ for rear motor mounts $30,  split rim jack $75, TT and T jacks, pair of oval gas tank brackets $35, left & right good outer front wheel bearings $25,  Restored Texas license plates from the 30s…. More to come
					Last edited by George House on Fri Mar 14, 2025 12:28 pm, edited 3 times in total.
				Gene_French
- First Name: Gene
- Last Name: French
i will continue to search thru my piles of stuff for interesting items to bring to the meet ... it can be difficult to determine what items may be of interest to or needed by a buyer ... also the difficulty of loading and transporting items that may not sell brings up the question ...what do people need , what are you looking for ? i am able to machine connecting rods and ball caps to your particular needs and can bring to this meet ...let me know what you need ...Gene French
				JSteele
- First Name: John P.
- Last Name: Steele
- * REQUIRED* Type and Year of Model Ts owned: 1915 Roadster
I'm bringing a pretty nice set of 5 Model T Pasco wheels with hubs and caps. Stan Howe had saved them for years for a speedster that did not get built.
Two sets of 30X 3.5 Disteel disc wheels and hubs. One set has new rims that John McLaren put on for me.
set of 21' Hayes wheels with hub caps
Needle nose pans from nice to need some work, 1 is a tea cup pan.
Miscellaneous other fine pieces of rust.
Contact info
Contact info
- Last Name: House
Please move to top
				Gene_French
- First Name: Gene
- Last Name: French
will be packing truck Monday ... have added a few additional items to my pile of stuff and will be heading out before any bad weather in this region ... hope all have a safe and uneventful drive to and back home from this meet ... see you all there ...Gene French
				Mike Lebsack-Iowa
- First Name: Mike
I am bringing a brand new pair of 17-25 rear touring/roadster fenders with all of the brackets. These list for $450 each plus shipping in the vendor catalogs and that does not include the brackets. I am asking $750 for the pair delivered to Duncan. I even have the little fender to apron brackets to go with them. Shipping is very expensive for boxed fenders so this is a very good opportunity to get new fenders.
				Mike Lebsack-Iowa
- First Name: Mike
				Gene_French
- First Name: Gene
- Last Name: French
truck is packed and ready to head south ... good news is that the rain/snow forecast for Tuesday has been revised to just windy ... glad to hear that ! hopefully a tail wind ... see you all there ... Gene French
