LED Headlight bulbs - FINALLY some decent ones
AdminJeff
This is an UNSOLICITED post. Sometimes you're just so impressed w/ a product you have to let everyone know about. I just installed 2 of these 6 volt LED Headlight bulbs
https://www.modeltford.com/item/6572LED.aspx
I'm literally BLOWN away, and it takes a LOT for me to say that about a product. These are actually originally made for video projectors which explains why the pattern is so precise and the brightness so insane. I had LED bulbs previously that I installed 8 or 10 years ago but they sucked. These are in a different galaxy. The design is also quite elegant - I don't know who designed them but they nailed it. You can rotate the beam for perfect alignment. and the high beams are actually high beams.
I drive w/ my lights on all the time. Both of these bulbs only draw about 1-2 amps, so hardly anything. Aside from the brightness, LED bulbs are better because they don't tax your generator and you can use a lower charge rate and add years of life to your generator. My business is refurbishing gens, so I lose out on this, but these bulbs are worth a look.
Jeff
Jeff
Moxie26
- First Name: Robert
- Last Name: Jablonski
Re: LED Headlight bulbs - FINALLY some decent ones
Jeff... I totally agree with your observations... I bought these bulbs a little over a year ago. Turned them on and threw the others out. It not only takes less power to use. These headlight bulbs, is also easier on your generator and really doesn't take that much power for that generator to replace in the battery. I also bought LED stop lights and tail lights .
ewdysar
- First Name: Eric
- Last Name: D
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Speedster #32, 1916 Touring, 1927 Runabout
I ordered a pair of these last week and they are currently crawling their way across the country to get to my house. I am looking forward to seeing the improvement. I’ll try and take before and after pics inside my darkened shop.
Eric
Eric
I believe you will be delighted.
Finally we have an LED bulb with its own lens that allows the beam to be directed. I have long railed against the substitute bulbs with multiple lED s in various arrays that just put out a great big blob of ill-directed bright blue light. These might even be appreciated by oncoming drivers if properly aligned.
Moxie26
https://youtu.be/VvbNY2s3Egs?si=m5bHBkWY2y2RjavL. ...... YouTube video. Bulbs can be used on either positive or negative grounded 6. Volt cars. . I purchased all my LED bulbs ,... Headlight, Stop, and Running, from... www.logolites.com.
AdminJeff
$50 on Logolites website.Moxie26 wrote: ↑Wed Mar 19, 2025 6:47 amh purchased all my LED bulbs ,... Headlight, Stop, and Running, from... www.logolites.com.
$37 on Langs website.
Moxie26
Bulbs were purchased from the manufacturer "Logo lights " before they were being sold by Lang's.
JohnM
- Last Name: Michaelree
- Board Member Since: 2010
I installed these in my 26 last summer and have been very happy with them for the reasons stated. The only downside is for those who like the golden color of incandescent bulbs. I do, but I would rather see and be seen.
WillyR
- First Name: Vilhelm
- Last Name: VonRaschke
- * REQUIRED* Type and Year of Model Ts owned: 1924 coupe
@adminjeff thanks for the heads up, I was looking to get them from logo....AdminJeff wrote: ↑Wed Mar 19, 2025 8:16 am$50 on Logolites website.Moxie26 wrote: ↑Wed Mar 19, 2025 6:47 amh purchased all my LED bulbs ,... Headlight, Stop, and Running, from... www.logolites.com.
Sent from the panic room, via two tin cans attached with a string, and a jail broken Marconi, while wearing a Tin Foil hat.
Moxie26
Using LED headlights will greatly reduce generator strain to charge the battery... Even less strain would be to use LED bulbs in your stop and rear marker lights.... Just as Jeff mentioned.
WillyR
I bought some LED bulbs for my new turn signal/stop lights, testing with a 7volt battery the incadescent were a lot brighter.
These were the press in type bulbs, I'll post a full report when I get my car...
You might be able to lightly tint your headlight lenses to simulate the incandescent look.
- First Name: Keith
- Last Name: Townsend
Are these single contact or double contact bulbs?
Moxie26
https://youtu.be/G7UePX5BowE?si=m7Jr1PedQET9RCj4. ..... Youtube video using a Model A rear lights .... directional signals/ brake lights/ flashers, also suggesting larger incandescent bulb to work with flashers.. I'm sure this would help with Model t's. The owners want to add flashers and directionals
Moxie26
Keith .... Those are double contact headlight bulbs.... The rear running lights and stoplight bulbs are single contact.... CP-1 or #1680 - 6 volt incandescent bulbs give a brighter glow and will work with directional flashers and 4 way flashers.
WillyR
I just ordered the bulbs from Lang's, they are 3-4 weeks out on a re-stock on them.
I have some bulbs I ordered from amazon @ $9 each, I'll install them in the mean time, and compare those to the stock bulbs, then compare the logos to the $9 bulbs when I get those....
- First Name: Austin
- Last Name: Farmer
If able, post your results!WillyR wrote: ↑Tue Apr 01, 2025 3:30 pmI just ordered the bulbs from Lang's, they are 3-4 weeks out on a re-stock on them.
WillyR
Lang's just got these back in stock today......
Tim D
- Last Name: Dickson
- * REQUIRED* Type and Year of Model Ts owned: 1912 speedster 1911 Torepdo
worth every penny. A great bulb.
dykker5502
- First Name: Michael
- Last Name: Deichmann
I have it in one of my T's and I am not super impressed, but maybe I should give it a little more in adjusting the lens.
Ford Model T 1914 Touring
WillyR
The bulbs I got from amazon would require some re-wiring, and since the logolites are plug and play, I decided not to try the amazon ones...1925 Touring wrote: ↑Wed Apr 02, 2025 11:28 amIf able, post your results!WillyR wrote: ↑Tue Apr 01, 2025 3:30 pmI just ordered the bulbs from Lang's, they are 3-4 weeks out on a re-stock on them.
I'll donate them to a club member
I had been using the factory bulbs on city streets with streetlights and my visibility was tolerable on the "dim" and "dimmer" settings...
The lens of these type of bulbs is pre-set. There is no adjustment for focus, only direction. The T reflector plays no part in the lighting effort, or the direction of the beam. This is how modern car lights work. On a T the direction is only adjustable by bending the stalk on the headlamp bucket.
WillyR
if anyone is interested these are the $10 led bulbs and the instructions on installation... these would be dependent on your reflectors....
not to brag but this is my local club....
https://www.amazon.com/gp/product/B07253LFHF/ref=0h aui detailpage o01 s00?ie=UTF8&psc=1
https://www.tinlizziesofabq.com/install ... a-model-t/
WillyR
I got my bulbs installed,
The adjustment on these is a little confusing, none of their videos explain it.
I imagine I need to be in the dark facing a wall to see what needs adjusting….
But already they look better and brighter.
Maybe they are not adjustable. Maybe all you can do is aim them correctly. That means bending the headlight stalks as appropriate. Original bulbs can be focused by adjusting the focus screw so their light can be properly reflected by the headlight reflector. Led's do not use the original reflector to focus their output.
WillyR
Ahh ha
So reading the full directions from the website helped..
It was much easier to check with the bezels off.
The beams are horizontal tv looking with the bright almost like a double image
Low
High
Video
https://youtube.com/shorts/JJF68c4rO-I? ... npQe49HfU1
Directions
https://www.logolites.com/wp-content/up ... dlight.pdf
Low
High
Video
Directions
Moxie26
You have the bulbs installed... Great!... The only thing you have to do is properly aim and you can still use the reflectors.
WillyR
Just in time for it to be light enough in the morning and evening not to need headlights to and from work...........
Moxie26
Not to worry Willy, ....., Mother Nature In time will change and your path to travel will be lit.
Harvey Bergstrom
- First Name: Harvey
- Last Name: Bergstrom
I too installed these LED headlight bulbs in my ‘24 Touring and am very happy with light I can actually see with driving at night. We don’t drive often at night, but if for some reason we are detained wherever we are, we drive home being able to see the road clearly. Also if a deer jumps out at me, I might be able to stop before I have a wreck. I’m all about safety. Glad so many fellow hobbyists enjoy the same thing I do. Happy motoring!
So, adjusting the bulb so the black strip is at the top is to get the beams parallel to the ground. That takes care of the orientation of the bulb in varying sockets. The shape and spread of the beam is fixed by the inbuilt lens the bulb has. As that lens sets the focus of the bulb, screwing the light focus screw should have no effect. Because the LED sends its output to the front, the Ford reflector is redundant. The only light it can reflect is that which may be scattered by the fluted lens in the headlamp. Or have I got it wrong, again.
I believe you are correct about focus, Allan. The stock reflector is not used. The fluted stock headlight lens may have a negative effect on the focused beam from the LED unit. If so, replacing the fluted lens with a plain flat lens should eliminate any problems.
WillyR
Not having a plain flat lense, I think the fluting helps diffuse the beam in a good way.TXGOAT2 wrote: ↑Thu May 01, 2025 7:27 pmI believe you are correct about focus, Allan. The stock reflector is not used. The fluted stock headlight lens may have a negative effect on the focused beam from the LED unit. If so, replacing the fluted lens with a plain flat lens should eliminate any problems.
It hides the horizontal “tv” shape a little.
So far I’m very happy.
There is an older version that uses the reflector, but it doesn’t look like Langs carries those.
The older ones which use the original reflectors are the problem child. LED's emit light on one direction only. To make use of the original reflectors in T head lights, and others, multiple stacks of LED's are used in various arrangements to point light at the reflectors. The result is a great big blob of ill directed, poorly focused white light hitting the road. I seriously doubt these type of bulbs meet any vehicle design rules/regulations.
ModelTMitch
- First Name: Mitch
- Last Name: Taylor
- * REQUIRED* Type and Year of Model Ts owned: 1924 Ford Model T touring
- Location: https://www.fordmodelt.net (Manning Valley, NSW, Australia)
I'm reluctant to use LED bulbs in my Model T... First off, they're not a period accessory, Second, they are way too bright for a 100 year old car, and Third, the light they throw is white! I'm sorry but Model T's are know for their annoyingly dim, yellowish headlamps! The solution, don't drive a Model T at night
☆☆ ModelTMitch ☆☆
★ Website: https://www.fordmodelt.net
★ YouTube: https://www.youtube.com/@ModelTMitch
★ Twitter: https://www.twitter.com/modeltmitch
★ Car Club: https://www.glhac.org
WillyR is correct, the fluted lens, a Frenzel Lens, is what focuses the light down the road.
The original flat glass head lights caused glare to on coming drivers. Laws were passed that resulted in a variety of designs. Many had hood eyelids a frenzel lens. We'll need to see what the results are with a fluted lens. It may make little difference since it was intended to create a horizontal pattern
From the Logo Lites website:
"Logo Lites Focused Beam LED Headlights feature a built-in lens to focus the bright white LEDs on the road in front of the car and not in the oncoming driver’s eyes. *Use your original headlight lenses in front of the replacement bulbs*. There is no need to polish the original headlight reflectors because the Focused Beam LED Headlights do not use the reflectors. In fact, there is no need for you to focus the headlights. The bulb lenses are focused at the factory and work with the headlight’s Fresnel lens to produce a modern light pattern on the road".
There's the answer to the lens question.
WillyR
I think that’s all fine and dandy, we all have our reasons for driving the venerable T.ModelTMitch wrote: ↑Sat May 03, 2025 11:40 pmI'm reluctant to use LED bulbs in my Model T... First off, they're not a period accessory, Second, they are way too bright for a 100 year old car, and Third, the light they throw is white! I'm sorry but Model T's are know for their annoyingly dim, yellowish headlamps! The solution, don't drive a Model T at night![]()
Personally I don’t want 12v or a distributor but I do want stop lights, turn signals, and visible headlights.
Most importantly I must have a stylish bud vase.. I haven’t decided if I will change the plastic flowers seasonally, this is a nice spring mix of wildflowers…
