I suspect that the supplier is no longer reproducing this part, as no supplier has them in stock any more. The APCO part for the radius rod is still available, but the one that fastens the radius rod to the pan is not...
I'd like to purchase a new or original part to help my dad bring his "shimmy" under control. He has a friend who will be going over the front end and has found numerous things to correct and this is one of them (but is the only part that I cannot find through the normal supply chain).
If you have one kicking around and want it to go to a worthy project, I'd sure be interested to hear from you.
thank you
WTB APCO spring loaded accessory located - thanks everyone - thanks MTFCA
Topic author - Posts: 6705
Re: WTB APCO spring loaded accessory - radius rod to pan
Really need to find one of these for my dad...
ThreePedalTapDancer
- First Name: Ed
- Last Name: Martin
Ed
sent you and email
thank you very much
sent you and email
thank you very much
Mark Chaffin
- Last Name: Chaffin
PM sent to you.
