Looking for a needle in a haystack
Topic author - Posts: 225
- First Name: David
- Last Name: Tagert
- * REQUIRED* Type and Year of Model Ts owned: 1926, 1925, 1923, 1921, 1918
I am looking for a NRS engine oil drain. It is a pepcock with a standpipe attached. Please contact me if you have an extra one - the engine has a pipe plug in the drain hole! I will buy two if I can find them. Thanks MTFCA !
- First Name: Galen
- Last Name: West
- * REQUIRED* Type and Year of Model Ts owned: 14 touring, 06 model N, 15 roadster, 18 centerdoor, 22 coupe, 23 chassis, 25 touring, 26 cut off, 26 coupe
Re: Looking for a needle in a haystack
David, I have an n as well. I have a lot of N stuff and will have to go out and look but maybe just maybe I may have what you need. I will go out to my shop and look right now Galen West 5415402596
- First Name: Galen
- Last Name: West
David, Can you call me? I have everal pet locks that may work. All will need stand pipes added but should not be a problem. Galen 541 540 2596 in Oregon
Email sent...
