Loading The Trailer for Luray
sweet23
Topic author - Posts: 526
- First Name: Darryl
- Last Name: Bobzin
- * REQUIRED* Type and Year of Model Ts owned: 2, '25 T Runabouts, '14 Touring
Trailer is getting full. Just two more weeks until the Mid Atlantic Pre-War Swap Meet in Luray VA. Make sure you stop by spaces G-9 & G10 For super deals. Prices to low to list here. Can't wait to see everyone ! Darryl
sweet23
- Last Name: Bobzin
Re: Loading The Trailer for Luray
What is everyone else bringing ? Post it here !
pkhammer
- First Name: Gregory
- Last Name: Hammer
- * REQUIRED* Type and Year of Model Ts owned: 1931 Town Sedan but looking for a T Touring
A 20' enclosed trailer with too much to list! Engine and trans parts, wheels, headlights, steering wheels, running board brackets, early aluminum trans cover, model A front axle complete with wishbone, spring and spindles plus tables full of good used parts and a HUGE (25 sq. ft) $1.00 box full of great stuff! Pricing parts to sell!
Dennis Fleming
- First Name: Dennis
- Last Name: Fleming
- * REQUIRED* Type and Year of Model Ts owned: 1913 touring,23 TT Express,23 Center Door,15 Touring,22 Speedster,22Coupe
Loading trailer for Luray!!!!
Much much more to load.
Dennis Fleming
I will have this 23-25 roadster top at Luray
Terry_007
- First Name: Terry
- Last Name: Bond
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Chassis
Looking forward to it. Got some early stuff-lamps, lit, rare spark plugs, quality automobilia,etc. Let me know if you have any early plugs to sell or trade.
Terry - in the back row.
Jones in Aiken SC
- Last Name: Jones
- * REQUIRED* Type and Year of Model Ts owned: 1912 Roadster, 1926 Coupe
Looking for some Rands brass windshield parts, particularly the cross strips, the ones that are the bottom of the top window frame and the top of the bottom window frame for a 11-12. A fella has to ask......
Brian Cress
- First Name: BRIAN
- Last Name: CRESS
- * REQUIRED* Type and Year of Model Ts owned: Speedsters, Roadster, Hack
I will be bringing a collection of Model T speed parts:
Several flat heads: Parker, Gemsa, Bud Hand, Sherman, and a modern CNC billet head.
Rajo BBR. Head only.
Aluminum intakes
Fronty S,T,R rocker arms. New modern reproductions with stands and shafts.
Accessory "Wrightford" sliding gear transmission. Replaces the original trans. and hogs head.
New Whippet radiator. Custom made for Model T speedster/racer.
Radiator shells, custom and original.
McLaren wire wheels.
26-27 wire wheels.
I am looking forward to seeing everyone there!
Aluminum intakes
26-27 wire wheels.
South Park Zephyr
- Last Name: Francis
- * REQUIRED* Type and Year of Model Ts owned: 25 RPU, 27 Roadster
- Board Member Since: 2022
How much for the top frame and canvas?
Scott
636-544-775zero
Scott
636-544-775zero
Racer_22
- Last Name: Prus
- * REQUIRED* Type and Year of Model Ts owned: 1910 Touring, 1912 torpedo, 1914 touring, 1919speedster, 1921 touring, 1922 touring 1925TTsemi, 1926 pickup, 1926 roadster
- Board Member Since: 2004
Im loading tonight. New Prus 280 T cams, new Prus 330 A/B cams. high compression heads, high volume outside oil line kits, new round and oval gas tanks and lots of good used T stuff.
ndnchf
- First Name: Stephen
- Last Name: Blancard
I'll be there with restored model T, A and flathead V8 generators.
Steve Blancard
Steve Blancard
pkhammer
- Last Name: Hammer
Looks like an isolated chance of a evening shower Thursday and Friday but otherwise the weather looks great!!I hope to see a big crowd there later this week!
Racer_22
- Last Name: Prus
Bringing a nice 1930 model A pickup to luray. Forgot to add it to the list. It has a fresh engine with high compression head and my new 330 lift a/b cam
Racer_22
- Last Name: Prus
Jim Suter Virginia
- First Name: Jim
- Last Name: Suter
- * REQUIRED* Type and Year of Model Ts owned: 1916 T Touring
Will be bringing a good assortment of Model T Ford mechanical parts and some sheet metal.
Other items of interest:
* Several nice 14/19 Touring Doors
* Five Black Plastic Coils
* Pair of 15/16 Rear Axle Housings
* Coils with good wood and windings suitable for rebuilding
* Engine Blocks:
20, std. bore
21, (early year) std. bore
15, (May casting date) on the rough side
*Stewart Model #131 Speedometer (needs rebuilding) for years 17, 18, 19
* Antique Tags in the teens for Ohio, PA and MD
Looking forward to seeing everyone.
Jim Suter, Harrisonburg, VA
* Engine Blocks:
20, std. bore
J1MGolden
- Last Name: Golden
Don Mueller and I will be bringing a trailer with 25 of those black, yellow top boxes full of nothing but Model T parts.
Here are a few:
15 Mostly Rebuilt brass carburetors.
4 New Old Stock Champion X Sark Plugs in the original boxes.
Here are a few:
J1MGolden
- Last Name: Golden
Here are a few:
Here are a few:
tdump
- First Name: Mack
- Last Name: Cole
i will be looking for 2 usable front fender brackets for 17-25 and 2 new bushings to go in front spring perches for 1926-7
also will be looking for what is apparently the next thing down the list from a unicorn, a pair of fender skirts for a 1947 pontiac streamliner. i will be making some measurements so i may not mess up and buy some that don/t fit.
will have in the truck a nos reproduction depot hack- exspress pickup fender and a 34 inch de-mountable rim i think may be for a 16 Buick. if anyone is in need of of those things, maybe help pay for the gas for my trip.
- Attachments
- screenshot-1746561474470.png (67.4 KiB) Viewed 3753 times
Dennis Fleming
Mack I will have several sets of front fender irons.
tdump
- First Name: Mack
- Last Name: Cole
good that means my trip is worth it in more ways than 1. they just need to be in good enough shape that i can straighten them and clean them up. i altered the set i have on my speedster and now i have found i can't use the lowering brackets i worked so hard to make. so i want to get a unaltered set so everything will be back stock size and lengthDennis Fleming wrote: ↑Tue May 06, 2025 4:02 pmMack I will have several sets of front fender irons.
tdump
- First Name: Mack
- Last Name: Cole
well i had a good time today at the shin dig. found me a nice set of fender irons for 20 each, bought some nice rear fenders that i don't mind making changes to for them to fit my speedster project for 30 bucks, got a high hood that i think has been in a fire for my ccab 1 ton future project for 20, and i now own a atwater kent distributor for a model t. i bought 2, 10$ each so i have the little gear and all the guts between the 2. picked up 2 cheap front fenders for my ccab project to.
there was alot of affordable model T sheet metal there this time.
Rick_Rice
- First Name: Rick
- Last Name: Rice
- * REQUIRED* Type and Year of Model Ts owned: 1925 TT Closed Cab Express
James Golden,
I just sent you and email.
Kind Regards,
Rick Rice
Kind Regards,
Rick Rice
