Clearance between crank and connecting rods
Papabear2121
First Name: Gary
Last Name: Fuller
Post by Papabear2121 » Thu Jun 27, 2019 8:03 am
Started final assembly of my 22 motor. New valves, lifters and rings. Ready to shim but need the specs for connecting rods to cram. Engine is original specs.
Kerry
Last Name: van Ekeren
Re: Clarence between crank and connecting rods.
Post by Kerry » Thu Jun 27, 2019 8:08 am
One and a half thou. .0015"
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Thu Jun 27, 2019 9:10 am
Fit the bearings with time saver yellow and it will give you the right clearance.
Last Name: Strange
Post by CudaMan » Thu Jun 27, 2019 9:36 am
Last Name: Juhl
Post by Oldav8tor » Thu Jun 27, 2019 10:44 am
I hope Clarence is OK :D
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Thu Jun 27, 2019 11:11 am
:lol: Clarence got his wings !! :lol:
ewdysar
First Name: Eric
Last Name: D
Post by ewdysar » Fri Jun 28, 2019 1:15 am
yep, I suggest that Clarence gets out from between the crank and connecting rods before anything gets tightened up... :roll:
