Clearance between crank and connecting rods
Topic author - Posts: 4
- First Name: Gary
- Last Name: Fuller
Started final assembly of my 22 motor. New valves, lifters and rings. Ready to shim but need the specs for connecting rods to cram. Engine is original specs.
- Last Name: van Ekeren
Re: Clarence between crank and connecting rods.
One and a half thou. .0015"
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
Fit the bearings with time saver yellow and it will give you the right clearance.
- Last Name: Strange
- Board Member Since: 2013
- Last Name: Juhl
I hope Clarence is OK
- Last Name: Hanlon
- Attachments
- IMG_4243.GIF (2.17 MiB) Viewed 3888 times
- First Name: Eric
- Last Name: D
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Speedster #32, 1916 Touring, 1927 Runabout
yep, I suggest that Clarence gets out from between the crank and connecting rods before anything gets tightened up...
