Wanted - Radius Rods for a 1925
wmscottsutherland
Last Name: Sutherland
Post by wmscottsutherland » Tue May 20, 2025 8:45 am
I need two rods for a rebuild. The two that were taken off have lost a good amount of thread due to rust.
Thanks for any help.
Scott
Ken Buhler
First Name: Ken
Last Name: Buhler
Board Member Since: 2012
Re: Wanted - Radius Rods for a 1925
Post by Ken Buhler » Tue May 20, 2025 9:33 am
Scott,
Do not scrap those, if they are not swollen they can be repaired. The ends are forged and can be welded.
Work honestly
Stay true to your word
Get the job done right
wmscottsutherland
Post by wmscottsutherland » Tue May 20, 2025 6:47 pm
Ken,
Any place to source weldable threaded ends for the rods or do you have to make them yourself?
First Name: craig
Last Name: leach
Post by Craig Leach » Tue May 20, 2025 8:16 pm
Hi Scott,
I don't know if these are the correct style? They came off a set that had the other end cut off & I used the middle to repair some broken top bows.
Post by RajoRacer » Tue May 20, 2025 8:25 pm
Those are later '26 & '27 with the "fixed" collars - early '26 used 2 nuts & a lock washer. The fork end is also different.
kmatt2
First Name: Kevin
Last Name: Matthiesen
Post by kmatt2 » Tue May 20, 2025 8:41 pm
Those cut off rods are for a late 1926-27 car and have the fixed collar. They would have to be welded to the old rods at exactly the correct length. I am sure that you could turn the collar off , weld threads up and rethread the entire length to use the two nuts like the stock 1925 rods using you stock 1925 rods with bad ends cut off and replaced with these ends. This will allow for some small adjustment in length because of the lock nuts.
wmscottsutherland
Post by wmscottsutherland » Wed May 21, 2025 4:17 pm
Got a set from Mark Chaffin. Thank you Mr. Chaffin.
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Wed May 21, 2025 4:19 pm
You're welcome Scott. Happy motoring! :)
