quick bolt set for model A & T Ford
Gene_French
Topic author - Posts: 1102
- First Name: Gene
- Last Name: French
- Board Member Since: 2014
i have made another run of "Quick Bolts " for fitting the mainbearings in Models A and T Ford ( 4 sets ) ... these are made from mild steel bolt stock as the originals ... the quick bolt reduces the time and labor in fitting the mains by reducing the time needed to remove and tighten the original bolts ...set includes the 6 bolts , nuts and forked keepers ... price of $150 plus $15.00 postage in lower 48 states ... actual postage outside this area or INTERNATIONAL ... Gene French 970-581-2808 or gfrench1953@hotmail.com
Gene_French
- First Name: Gene
- Last Name: French
Re: quick bolt set for model A & T Ford
to the top again , thanks MTFCA
Gene_French
- First Name: Gene
- Last Name: French
to the top again ...thanks MTFCA
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
to the top again ... thanks MTFCA
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
will have quick bolt sets on display at the Duncan<ok. swapmeet in March ... stop in and visit ...Gene French 970-581-2808 or gfrench1953@hotmail.com
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
