Rear axle dumb question of the day
Daisy Mae
First Name: Kurt
Last Name: Andersson
Board Member Since: 2024
Post by Daisy Mae » Sat May 31, 2025 1:43 pm
So I'm in process of setting up my rear axle.
The original thrust bearing washers ate thru the pins and subsequently dropped enough to chew into the diff carrier collar. Assembling the new means setting the washers with some grease to hold in place and keep the plates dropping off the pins. The goal, both for rebuild, as well as operation, is for those thrust plates to be stationary sandwiching the floating brass plate.
Both of which got me thinking...
Has anyone ever considered, or actually done, gluing the pinned plates with JB Weld?
Positives:
* makes assembly much easier considering the multiple times the halves must be fitted (but requiring temporary full set up in order to ensure as best alignment as possible to set up in place)
* keeps the plates in place and eliminates risk of coming off the pins and destroying the diff carrier or worse
* reduces sheer movement of the plates from eating the pins in the first place
Negatives:
* difficulty in properly setting and potential of introducing misaligned thrust plates
* inability to introduce shim plates
* nobody would want to face the prospect of rebuilding a glued up axle in the future
* lazy way out of properly taking time to set up the axle
So, pretty much have answered my own question relative to not being a good idea, but was curious whether anyone has ever done so, and if so, your reasons. I did various word searches on glued thrust plates and got nothing, but I can't possibly be the only one with such a hair brained idea!
Fire away! I know lots of opinions exist here! LOL
Re: Rear axle dumb question of the day
Post by speedytinc » Sat May 31, 2025 2:03 pm
Not had an issue with loosing the thrust washers during assembly.
I assemble the axle housings in a vertical position using a pipe vise mounted sideways on a stand.
Real easy for a no drag side thrust & gear mesh determination.
Your reasoning for not gluing the thrust washers is sound.
Ed Fuller
First Name: Ed
Last Name: Fuller
Board Member Since: 2012
Post by Ed Fuller » Sat May 31, 2025 2:46 pm
You need some stickier grease.
Post by Steve Jelf » Sat May 31, 2025 3:15 pm
Not being a real mechanic, I tried to follow Glen's directions in the axle book. He knew his stuff and it worked.
Daisy Mae
First Name: Kurt
Post by Daisy Mae » Sat May 31, 2025 3:29 pm
Yup, that's what I'm following, Glenn's write up.
Post by DanTreace » Sat May 31, 2025 3:31 pm
Have used JB Weld, not on the plates but once on a pin that fit a tad loose in a worn out hole, just a smear to lock the pin.
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Sat May 31, 2025 3:57 pm
You have to throw away the bad parts and use good ones.
Post by Jerry VanOoteghem » Sat May 31, 2025 4:28 pm
JB Weld is a good product. However, it has no place in a Model T rear end.
Just to answer a couple of your points...
That's impossible as long as the thrust plates have not disintegrated, which will not happen with bronze.
That would not be an issue, since the JB would have long ago broken loose and crumbled into the rear end.
Daisy Mae
First Name: Kurt
Post by Daisy Mae » Sat May 31, 2025 6:05 pm
My axle, while still miraculously working, was toast. The only things being reused in the rebuild are the axle halves and torque tube. Most all else are new parts:
Axles
Drive shaft
Drive shaft tapered roller bearing cartridge
DS bushing
Ring & pinion
Axle roller sleeves
Inner & outer seals
Thrust bearing & plates
Thrust plate pins
Brake cam bushings
Brake cams & arms
lined brake shoes
All new bolts/nuts
All new keys/rings
"New" good condition used parts:
Diff carrier
Spider assembly
Axle gears
Hyatt axle rollers
Been a slow process getting every thing cleaned up, fitted, verifying tolerances. I pulled in the brake cam bushings and set the cams today and building a cradle to set the housing upright on my bench. Tomorrow I'll be ready to begin fitting the internals and checking/setting clearances.
My mind wanders while doing stuff, ergo the odd thought...
Daisy Mae
First Name: Kurt
Post by Daisy Mae » Sat May 31, 2025 6:22 pm
@ Jerry
Well, not quite impossible...
Between my axle bearings being shot, and the fact that my diff carrier studs all worked loose (cottered, not wired) introducing a ton of slop in the carrier, one diff pin was eaten where the loose plate had deeply cut thru the diff collar.
But to your point, yes, impossible if tolerances remain in spec. Where my thought was thinking of mitigating against the future day of opened clearances such as I encountered.
But....once I'm done, at least I know it'll be good the rest of my life....so...like A.P. Newman, what, me worry?
