Gasket under Fronty valve cover?
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Mon Jun 09, 2025 9:14 pm
Should there be a gasket under the valve cover for a Frontenac overhead valve head?? I've got an oil soaked typewriter felt above the rocker assembly. I dont want oil drooling down the sides on my engine.
Keith
Re: Gasket under Fronty valve cover?
Post by RajoRacer » Mon Jun 09, 2025 10:22 pm
I made one for my BB RAJO - it helps !
babychadwick
First Name: Chad
Last Name: Azevedo
Post by babychadwick » Tue Jun 10, 2025 8:38 am
I sealed mine down, to oil the pad I drilled and tapped for 3 clean grease cups. Simply unscrew the cap, pour in the oil and you're done.
Post by Jerry VanOoteghem » Tue Jun 10, 2025 9:28 am
Maybe a similar application... My '24 Buick has a looong rocker cover. It leaked oil too. On the advice of a "Buick guy", my dad made a gasket out of 1/4" thick, rubberized cork. It's been in place for over 30 years and works great. It's held in place with Permatex on the bottom side only. The thickness allows it to conform well with any irregularities in the cover.
tman1913
Last Name: Bender
* REQUIRED* Type and Year of Model Ts owned: 1913 Canadian touring, 1924 Roadster, 1926 Mercury speedster, 1927 Roadster p/u, 1920’s bobtail dirt track racer
Post by tman1913 » Tue Jun 10, 2025 11:31 am
I agree with what Jerry suggested. Rubberized cork works very well. If you have a company that makes gaskets near you, I have bought and most of the time gave what they refer to as drops. It also helps if you make sure the flange of the cover is flat.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Wed Jun 11, 2025 9:35 am
Chad, I have thought about drilling and tapping the cover to install some oilers, but hate to put holes in the cover. However, to oil the rockers, the hood needs to be removed, then the cross-over carburetor heat-pipe has to be removed, and finally the valve cover has to be removed, then i can give the rocker assembly a couple of squirts. Then, put it all back together again...
Howard Tomlinson
First Name: Howard
Last Name: Tomlinson
Post by Howard Tomlinson » Wed Jun 11, 2025 9:00 pm
For the gasket I bought a sheet of cork material from the local tractor store. I traced the valve cover and cut the material to fit. Still working on the engine rebuild, so I haven't run it yet.
FWIW, my valve cover, valve chest cover and intake block off plate are the reproduction aluminum parts. They were true rough castings (rough and warped). I took them to a local engine shop and they surfaced the mating surfaces.
Thanks,
