speedometer gear identification
Art Ebeling
First Name: Art
Last Name: Ebeling
Post by Art Ebeling » Tue Jun 10, 2025 10:13 am
What year are these speedometer gears for? One has number 2 on it and the other number 3. Art
Russ_Furstnow
First Name: Russ
Last Name: Furstnow
Re: speedometer gear identification
Post by Russ_Furstnow » Tue Jun 10, 2025 10:25 am
The gears you have are "Circle Ess" gears that have 16 teeth. The #2 gear is a 9 pitch gear and the #3 gear is a 10 pitch gear. Generally, Jones Speedometer Co. and Stewart Speedometer Co. used 9 pitch gears, while Warner used 10 pitch gears. These gears were used with swivel joints or direct drives. These gears were not used on a Model T Ford. I hope this helps. Russ Furstnow
Last edited by Russ_Furstnow on Tue Jun 10, 2025 11:05 am, edited 2 times in total.
Art Ebeling
First Name: Art
Last Name: Ebeling
Post by Art Ebeling » Tue Jun 10, 2025 10:29 am
Thanks Russ. Art
