Dodged a bullet….
1915ford
Last Name: Cameron
Dodged a bullet….
Post by 1915ford » Mon Jul 07, 2025 9:52 pm
Was out in the fifteen last week and just as i am pulling back into the garage the low pedal got weird. Then i heard the tell tale sound of a fastener bouncing around inside the oil pan. Pulled the inspection cover and three of the six backing plate bolts were sitting in the filter. I had been in the habit of using loctite on them and no safety wire as it seems to cause more problems than it solves. Must have forgot the loctite this time….sure do like that filter thingy.
Re: Dodged a bullet….
Post by Allan » Tue Jul 08, 2025 12:12 am
Do you mean the 6 bolts which attach the driven plate to the brake drum? I would not trust Loctite of any persuasion there. It likely gets too hot for Loktite, the bond of which is often indicated can be broken with heat for removal. Is there a super high temp agent they make?
Allan from down under
Post by Jerry VanOoteghem » Tue Jul 08, 2025 6:27 am
Completely agree! Even if Loctite was a valid solution, at this point, you'll never get the threaded holes clean enough for the Loctite to be effective. Please use the wire.
John E. Guitar
Last Name: Guitar
Board Member Since: 2012
Post by John E. Guitar » Tue Jul 08, 2025 8:43 am
That was a lucky catch Mark!
In response to Allan, Loctite 243 or 263 would be fine in that location. The transmission won’t get close to the temperature where either of those products starts to loosen up and your threads don’t need to be super clean either.
Post by TXGOAT2 » Tue Jul 08, 2025 9:30 am
Use Loctite AND wire.
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Tue Jul 08, 2025 10:57 am
Eagads, loctite instead of safety wire?!
