cotter pin size
Moxie26
Last Name: Jablonski
cotter pin size
Post by Moxie26 » Sun Jul 20, 2025 10:50 am
What size cotter pin used in clutch finger adjustment?.... Diameter and length. Thanks in advance
Daisy Mae
First Name: Kurt
Last Name: Andersson
Re: cotter pin size
Post by Daisy Mae » Sun Jul 20, 2025 12:16 pm
I just use a rule of thumb to use as big a pin as possible to fully occupy the bolt hole, the pin head expanded into the nut slot, then trimmed to length to bend one arm down the side of the nut, the other arm up and across the top of the bolt.
Re: cotter pin size
Post by Steve Jelf » Sun Jul 20, 2025 3:53 pm
I don't guarantee accuracy, but the Fahnestock book has a
cotter pin list that's mostly correct.
:D
Re: cotter pin size
Post by speedytinc » Sun Jul 20, 2025 4:43 pm
:D
Looking @ past posts, I did not see the specific pin for the output plate listed.
Re: cotter pin size
Post by DanTreace » Mon Jul 21, 2025 2:02 pm
Per Bruce's CD parts listing, the cotter for the clutch finger adjusting screw is Factory No. 757 , as shown on the cutaway drawing.
Cotter pin, 3/32 x 7/8". Clutch finger
Moxie26
Re: cotter pin size
Post by Moxie26 » Mon Jul 21, 2025 3:39 pm
Dan... Many thanks again, appreciate your help.
