cotter pin size
Moxie26
Topic author - Posts: 2072
- Last Name: Jablonski
cotter pin size
What size cotter pin used in clutch finger adjustment?.... Diameter and length. Thanks in advance
Daisy Mae
- First Name: Kurt
- Last Name: Andersson
- Board Member Since: 2024
Re: cotter pin size
I just use a rule of thumb to use as big a pin as possible to fully occupy the bolt hole, the pin head expanded into the nut slot, then trimmed to length to bend one arm down the side of the nut, the other arm up and across the top of the bolt.
Re: cotter pin size
I don't guarantee accuracy, but the Fahnestock book has a
cotter pin list that's mostly correct.
Re: cotter pin size
Looking @ past posts, I did not see the specific pin for the output plate listed.Steve Jelf wrote: ↑Sun Jul 20, 2025 3:53 pmI don't guarantee accuracy, but the Fahnestock book has a
cotter pin list that's mostly correct.![]()
Re: cotter pin size
Per Bruce's CD parts listing, the cotter for the clutch finger adjusting screw is Factory No. 757 , as shown on the cutaway drawing.
Cotter pin, 3/32 x 7/8". Clutch finger
Moxie26
Re: cotter pin size
Dan... Many thanks again, appreciate your help.
