Replacement carb float
Topic author - Posts: 1624
- First Name: Rich
- Last Name: Bingham
My Lizzie pulled up with a belly-ache the other day, woes with the Holley G I’m running. It’s a brass-body G I rebuilt about 7 years ago, using the available composite foam float available from Lang’s. As usual, it’s never just one thing wrong, found a little crud in the inlet port, and the float valve prospered by “lapping” with toothpaste. When I could not get the float level set properly, I finally accepted the fact that the float had become “waterlogged” in gasoline. Replaced the float with a new one of the same material, problem solved.
Just wondering if others have found this float material will eventually soak up and sink ?
Tiny bits of unidentified “crud” from the inlet passage
Get a horse !
- Last Name: Gould
Re: Replacement carb float
The float material I purcased from Langs was closed cell. I rebuild a few floats using this stuff some years ago and havent had an issue.
I dont know if this makes a difference but I puchased blocks of the material and made my own using originals as a guide. I never sealed them.
- First Name: Rich
Both from the same source, perhaps we can assume it’s the same stuff ? It appears to be the same vis-a-vis the photo. Lang’s catalogue only specifies “modern material”. Just curious whether anyone else has found that it will absorb fuel “in time” ?
BTW, Nice work on that float, Richard !
Get a horse !
Differences in mandated gasoline additives from one area to another might be a factor.
- First Name: Rich
Pat, I wondered if that could be the case. I shouldn’t complain about failure after several years, but it caught me off guard.
Get a horse !
- First Name: Jeffrey
- Last Name: Hausey
Nitrophyl is the material now in Holley, Carter, Quadrajets, etc.
It's impervious to gas and alcohol.
- First Name: Rich
Thank you, Jeffrey. That’s instructive. Now to research it and determine if it can be formed into Model T carb floats.
Identifying the material Lang’s provides is still a problem.
Get a horse !
