FS set of shackles
Topic author - Posts: 497
- First Name: Clay
- Last Name: Atkins
- * REQUIRED* Type and Year of Model Ts owned: 1921 Roadster
FS set of shackles
For Sale: one set of shackles. Ford Script.
$110 includes shipping to lower 48
- First Name: Clay
- Last Name: Atkins
Re: FS set of shackles
to the top
- First Name: Clay
- Last Name: Atkins
to the top
- First Name: Ken
- Last Name: Buhler
- * REQUIRED* Type and Year of Model Ts owned: 1927 Roadster 1927 Coupe
- Board Member Since: 2012
Clay,
In fairness, Those are why we replace them. If you would show what they measure with a micrometer both ways, you will know what I mean.
Work honestly
Stay true to your word
Get the job done right
Clay, those are early L shaped shackles, superseded by the later U shaped ones. To my knowledge they are not reproduced. Yours are relatively easy to rebuild with weld and then machined back to size. You have the basics of a complete set for someone wanting the correct type for their car.
- First Name: Clay
- Last Name: Atkins
These will probably outlast the repops and they are $305 a set. They are also Ford Script.
Junk or repair? Original repair or repops?
- First Name: Marc
- Last Name: Roberts
- * REQUIRED* Type and Year of Model Ts owned: 1914 Runabout, 1916 Touring
What years would these be correct on?
They followed the figure 8 shackles with the brass oilers. On our Canadian sourced cars they were used up until 1925 or thereabouts. I believe US production went to the U shaped shackles earlier.
